You're viewing a previously published version of this guide.  View latest version
Older Newer
Nexus 9 Battery Replacement
Kelsey Rodriguez
Kelsey Rodriguez and 6 other contributors
Last updated on June 30, 2022
5 minutes
Easy
Featured Student Guide
Introduction
Go to step 1
Use this guide to replace the battery in your Nexus 9.
Parts
Tools
  • Spudger
    Spudger
  • iOpener
    iOpener
Show more…
  1. Nexus 9 Battery Replacement, Rear Case: step 1, image 1 of 3 Nexus 9 Battery Replacement, Rear Case: step 1, image 2 of 3 Nexus 9 Battery Replacement, Rear Case: step 1, image 3 of 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Battery Replacement, Battery: step 2, image 1 of 2 Nexus 9 Battery Replacement, Battery: step 2, image 2 of 2
    • Carefully peel up the copper shielding with your fingers.
    • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
  3. Nexus 9 Battery Replacement: step 3, image 1 of 1
    • Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
    • The battery is attached to the motherboard with some adhesive, so you may need an iOpener to loosen up the adhesive. Check out the iOpener guide for info on how to do it.
    • Do not pull the battery from the tablet yet, as it is still connected to the motherboard.
  4. Nexus 9 Battery Replacement: step 4, image 1 of 1
    • Now remove the metal clip covering the battery's connector cable located above the top left of the battery with the spudger.
    • After the metal clip is wiggled free, the battery's connector cable can be easily removed by just gently tugging it free.
  5. Nexus 9 Battery Replacement: step 5, image 1 of 1
    • The battery should now lift free of the tablet.
Kelsey Rodriguez
874 Reputation
2 Guides authored
Cal Poly, Team 19-11, Maness Winter 2015 Member of Cal Poly, Team 19-11, Maness Winter 2015
CPSU-MANESS-W15S19G11
5 Members
7 Guides authored
Past 24 Hours: 5
Past 7 Days: 13
Past 30 Days: 25
All Time: 29,620
