Nexus 9 Front Facing Camera Replacement
  1. Nexus 9 Front Facing Camera Replacement, Rear Case: step 1, image 1 of 3 Nexus 9 Front Facing Camera Replacement, Rear Case: step 1, image 2 of 3 Nexus 9 Front Facing Camera Replacement, Rear Case: step 1, image 3 of 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
  2. Nexus 9 Front Facing Camera Replacement, Front Facing Camera: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Use a spudger to disconnect the front-facing camera ZIF connector.
    • Use a pair of tweezers to gently lift the front-facing camera up from the motherboard.
Geoff Wacker
92,109 Reputation
89 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 923
