Nexus One Antenna Housing Replacement
  1. Nexus One Antenna Housing Replacement, Lower Cover: step 1, image 1 of 2 Nexus One Antenna Housing Replacement, Lower Cover: step 1, image 2 of 2
    • Using the plastic opening tool, push the blade into the space between the case and lower cover.
    • Turn the opening tool slightly, the lower cover will detach on that side.
    • Repeat on other side of the seam.
    • The lower cover will slide off.
  2. Nexus One Antenna Housing Replacement, Antenna Housing: step 2, image 1 of 1
    • Remove the one T5 Torx screw
    • Remove the one #00 Philips screw
    • Lift up the end of the antenna housing and slide it outwards.
3 other people completed this guide.
Niklas Johnson
1,207 Reputation
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 3,717
