Nexus One Secondary Microphone Replacement
  1. Nexus One Secondary Microphone Replacement, Rear Cover: step 1, image 1 of 2 Nexus One Secondary Microphone Replacement, Rear Cover: step 1, image 2 of 2
    • Using two fingers, push up on the rear cover.
  2. Nexus One Secondary Microphone Replacement: step 2, image 1 of 1
    • The rear cover slides up and off.
  3. Nexus One Secondary Microphone Replacement, Battery: step 3, image 1 of 1
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Nexus One Secondary Microphone Replacement: step 4, image 1 of 1
    • Pull the battery up and out.
  5. Nexus One Secondary Microphone Replacement, Battery Housing: step 5, image 1 of 1
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Nexus One Secondary Microphone Replacement: step 6, image 1 of 2 Nexus One Secondary Microphone Replacement: step 6, image 2 of 2
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Nexus One Secondary Microphone Replacement: step 7, image 1 of 2 Nexus One Secondary Microphone Replacement: step 7, image 2 of 2
    • Pry the upper left tab open on the battery housing.
  8. Nexus One Secondary Microphone Replacement: step 8, image 1 of 2 Nexus One Secondary Microphone Replacement: step 8, image 2 of 2
    • Pry the top tab of the battery housing.
  9. Nexus One Secondary Microphone Replacement: step 9, image 1 of 2 Nexus One Secondary Microphone Replacement: step 9, image 2 of 2
    • Pry the right side tab of the battery housing.
  10. Nexus One Secondary Microphone Replacement: step 10, image 1 of 2 Nexus One Secondary Microphone Replacement: step 10, image 2 of 2
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Nexus One Secondary Microphone Replacement, Secondary Microphone: step 11, image 1 of 2 Nexus One Secondary Microphone Replacement, Secondary Microphone: step 11, image 2 of 2
    • Using the spudger, pry upwards on the second microphone connector.
  12. Nexus One Secondary Microphone Replacement: step 12, image 1 of 1
    • Pull up on the ribbon cable, the tape will detach from the main board ribbon.
Niklas Johnson
1,207 Reputation
18 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 29
All Time: 2,374
