Nexus Q Ball Bearing Ring Replacement
  1. Nexus Q Ball Bearing Ring Replacement, Ball Bearing Ring: step 1, image 1 of 1
    • Squeeze and pull the cap to remove it from the Nexus Q.
  2. Nexus Q Ball Bearing Ring Replacement: step 2, image 1 of 1
    • Use a spudger to disconnect the Taoglas Wi-Fi Dual Band Antenna.
  3. Nexus Q Ball Bearing Ring Replacement: step 3, image 1 of 1
    • Undo the ZIF connector by prying it with a spudger.
  4. Nexus Q Ball Bearing Ring Replacement: step 4, image 1 of 1
    • Use a Phillips #0 screwdriver to unscrew the four 1.3 mm screws.
    • After removing the screws, there will be two parts. The top part contains the daughterboard. Store it safely. It will not be used.
  5. Nexus Q Ball Bearing Ring Replacement: step 5, image 1 of 1
    • View the bottom half of the Nexus Q.
    • Use a Phillips #0 screwdriver to remove the four 0.8 mm screws holding the ball bearing ring in place.
  6. Nexus Q Ball Bearing Ring Replacement: step 6, image 1 of 1
    • Remove the ball bearing ring.
    • When placing a new ring in its place, make sure to orient it right or the top will not close.
Taewan Kim
22 Reputation
2 Guides authored
Cal Poly, Team 7-10, Maness Winter 2013 Member of Cal Poly, Team 7-10, Maness Winter 2013
CPSU-MANESS-W13S7G10
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 577
