Nexus S Motherboard Replacement
  1. Nexus S Motherboard Replacement, Rear Panel: step 1, image 1 of 1
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Nexus S Motherboard Replacement: step 2, image 1 of 1
    • Remove the rear panel from the Nexus S.
  3. Nexus S Motherboard Replacement, Battery: step 3, image 1 of 1
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
  4. Nexus S Motherboard Replacement, SIM Card: step 4, image 1 of 2 Nexus S Motherboard Replacement, SIM Card: step 4, image 2 of 2
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
  5. Nexus S Motherboard Replacement, Rear Inner Frame: step 5, image 1 of 1
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  6. Nexus S Motherboard Replacement: step 6, image 1 of 1
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  7. Nexus S Motherboard Replacement: step 7, image 1 of 2 Nexus S Motherboard Replacement: step 7, image 2 of 2
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  8. Nexus S Motherboard Replacement: step 8, image 1 of 2 Nexus S Motherboard Replacement: step 8, image 2 of 2
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  9. Nexus S Motherboard Replacement: step 9, image 1 of 1
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  10. Nexus S Motherboard Replacement: step 10, image 1 of 1
    • Lift and remove the rear inner frame from the Nexus S.
  11. Nexus S Motherboard Replacement, Motherboard: step 11, image 1 of 1
    • Disconnect the following cables from their respective sockets on the motherboard:
    • Headphone jack cable
    • Digitizer cable connector
    • Camera/SIM board connector
  12. Nexus S Motherboard Replacement: step 12, image 1 of 3 Nexus S Motherboard Replacement: step 12, image 2 of 3 Nexus S Motherboard Replacement: step 12, image 3 of 3
    • Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
    • Make sure to pry on the connector and not the socket itself. Prying the socket may cause severe damage.
    • Repeat the procedure for the digitizer and rear camera/SIM board connectors.
  13. Nexus S Motherboard Replacement: step 13, image 1 of 1
    • Remove the three Phillips screws securing the motherboard to the front display assembly.
  14. Nexus S Motherboard Replacement: step 14, image 1 of 2 Nexus S Motherboard Replacement: step 14, image 2 of 2
    • Wedge the plastic opening tool near the bottom right corner of the motherboard and pry upwards to dislodge it from its recess.
    • Lift and remove the motherboard.
15 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 13,866
