Nike SportWatch GPS Back Panel Replacement
  1. Nike SportWatch GPS Back Panel Replacement, Back Panel: step 1, image 1 of 1
    • Face the watch upside down, so that the back of the watch is exposed. Unscrew the six #000 size 5 mm long screws on the back using a size 000 Phillips head screwdriver.
  2. Nike SportWatch GPS Back Panel Replacement: step 2, image 1 of 1
    • Carefully separate the watch by pulling the band away from the main board.
  3. Nike SportWatch GPS Back Panel Replacement: step 3, image 1 of 1
    • Pry the black plastic piece above the battery out using a nylon or metal spudger.
    • Be careful not to break the metal flat bands located above the plastic piece. They are fragile and easily breakable.
  4. Nike SportWatch GPS Back Panel Replacement: step 4, image 1 of 1
    • Using a guitar pick removal tool, push under the battery to pry the battery out of the watch.
  5. Nike SportWatch GPS Back Panel Replacement: step 5, image 1 of 1
    • After taking the battery out, you will be left with just the band and the backpanel part of the watch.
Ian Eichorn
678 Reputation
4 Guides authored
3 Comments
Where can I find a new watch band?
rhalljr68 - Reply
You canĀ“t. Nike left us alone
Leonardo Cartier - Reply
So, no way to repair the band then if there's no replacement parts? :(
roycy Tan - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 2,565
