Nike SportWatch GPS Front Panel Replacement
  1. Nike SportWatch GPS Front Panel Replacement, Front Panel: step 1, image 1 of 1
    • Face the watch upside down so that the back of the watch is exposed. Unscrew the six size #000 5 mm long screws on the back using a size 000 Phillips head screwdriver.
  2. Nike SportWatch GPS Front Panel Replacement: step 2, image 1 of 1
    • Carefully separate the watch by pulling the band away from the main board.
  3. Nike SportWatch GPS Front Panel Replacement: step 3, image 1 of 1
    • Two size #000 2.5 mm long screws will appear at the top of the main board. Unscrew them using a size 000 Phillips head screwdriver.
  4. Nike SportWatch GPS Front Panel Replacement: step 4, image 1 of 1
    • Carefully use the blue plastic opening tool to pry the main board out of the front panel.
    • Make sure to be gentle so the ribbon cable that connects to the band does not break, it is fragile and not removable.
  5. Nike SportWatch GPS Front Panel Replacement: step 5, image 1 of 1
    • Use an iOpener that has been heated in the microwave for about a minute, or until warm. Place it on the front screen of the watch. Let it rest there for a minute.
    • If you are unfamiliar with this tool use the iOpener guide here
  6. Nike SportWatch GPS Front Panel Replacement: step 6, image 1 of 1
    • Push the panel out from the back of the screen, using your fingers.
Ian Eichorn
678 Reputation
4 Guides authored
One Comment
Where I can find the replacement glass? regards
Erick Sobreiro - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,271
