Nikon 1 J5 Keypad Replacement
  1. Nikon 1 J5 Keypad Replacement, Remove Micro SD card and Battery: step 1, image 1 of 1
    • Remove Micro SD card and Battery
  2. Nikon 1 J5 Keypad Replacement: step 2, image 1 of 3 Nikon 1 J5 Keypad Replacement: step 2, image 2 of 3 Nikon 1 J5 Keypad Replacement: step 2, image 3 of 3
    • Remove 2 screws
    • Open plastic LCD connector cover
    • Lift FPC connector latch
    • Detach LCD FPC
  3. Nikon 1 J5 Keypad Replacement, Detail of the FPC connector: step 3, image 1 of 3 Nikon 1 J5 Keypad Replacement, Detail of the FPC connector: step 3, image 2 of 3 Nikon 1 J5 Keypad Replacement, Detail of the FPC connector: step 3, image 3 of 3
    • The FPC cable is inserted from right side of this photo.
    • Insert a fine tip tweezer or any thin flat tip tool under the latch, and gentally lift it.
    • The latch rotates CCW for about 90 degrees
  4. Nikon 1 J5 Keypad Replacement: step 4, image 1 of 3 Nikon 1 J5 Keypad Replacement: step 4, image 2 of 3 Nikon 1 J5 Keypad Replacement: step 4, image 3 of 3
    • Remove 4 screws
    • Remove LCD module
  5. Nikon 1 J5 Keypad Replacement, Back Case: step 5, image 1 of 1
    • WARNING!!! DO NOT TOUCH THESE Solder joints!!! High Voltage up to 300V..
    • Or discharge the flash condenser first, as per "Main PCB replace guide"
    • Remove 3 screws
  6. Nikon 1 J5 Keypad Replacement: step 6, image 1 of 3 Nikon 1 J5 Keypad Replacement: step 6, image 2 of 3 Nikon 1 J5 Keypad Replacement: step 6, image 3 of 3
    • Left side, in connector bay, remove 2 screws.
    • Bottom, reomve 2 screws
    • Right side, remove 1 screw
  7. Nikon 1 J5 Keypad Replacement: step 7, image 1 of 1
    • Peel here and remove 1 screw within.
  8. Nikon 1 J5 Keypad Replacement: step 8, image 1 of 2 Nikon 1 J5 Keypad Replacement: step 8, image 2 of 2
    • Pop open back case and remove it from body.
  9. Nikon 1 J5 Keypad Replacement, Keypad: step 9, image 1 of 3 Nikon 1 J5 Keypad Replacement, Keypad: step 9, image 2 of 3 Nikon 1 J5 Keypad Replacement, Keypad: step 9, image 3 of 3
    • Disconnect speaker
    • Disconnect keypad FPC
  10. Nikon 1 J5 Keypad Replacement: step 10, image 1 of 1
    • Push latches from below
    • pop up and remove keypad.
Terrance
6,793 Reputation
19 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 34
All Time: 330
