Nikon 1 J5 LCD Module Replacement
  1. Nikon 1 J5 LCD Module Replacement, Remove Micro SD card and Battery: step 1, image 1 of 1
    • Remove Micro SD card and Battery
  2. Nikon 1 J5 LCD Module Replacement: step 2, image 1 of 3 Nikon 1 J5 LCD Module Replacement: step 2, image 2 of 3 Nikon 1 J5 LCD Module Replacement: step 2, image 3 of 3
    • Remove 2 screws
    • Open plastic LCD connector cover
    • Lift FPC connector latch
    • Detach LCD FPC
  3. Nikon 1 J5 LCD Module Replacement, Detail of the FPC connector: step 3, image 1 of 3 Nikon 1 J5 LCD Module Replacement, Detail of the FPC connector: step 3, image 2 of 3 Nikon 1 J5 LCD Module Replacement, Detail of the FPC connector: step 3, image 3 of 3
    • The FPC cable is inserted from right side of this photo.
    • Insert a fine tip tweezer or any thin flat tip tool under the latch, and gentally lift it.
    • The latch rotates CCW for about 90 degrees
  4. Nikon 1 J5 LCD Module Replacement: step 4, image 1 of 3 Nikon 1 J5 LCD Module Replacement: step 4, image 2 of 3 Nikon 1 J5 LCD Module Replacement: step 4, image 3 of 3
    • Remove 4 screws
    • Remove LCD module
Terrance
6,765 Reputation
19 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 28
All Time: 773
