Nikon COOLPIX P2 WiFi Card Replacement
Joshua Avery
Joshua Avery and 5 other contributors
Last updated on July 7, 2020
30 minutes
Moderate
Action Shots
Tools
Show more…
  1. Nikon COOLPIX P2 WiFi Card Replacement, Case: step 1, image 1 of 1
    • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
  2. Nikon COOLPIX P2 WiFi Card Replacement: step 2, image 1 of 1
    • Turn camera upside down so that the battery compartment is facing you.
    • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
  3. Nikon COOLPIX P2 WiFi Card Replacement: step 3, image 1 of 1
    • Rotate the camera to the opposite side where the A/V outlet is located.
    • Unscrew and remove all four screws with a Phillips 00 screwdriver.
  4. Nikon COOLPIX P2 WiFi Card Replacement: step 4, image 1 of 1
    • Turn the camera so that the Wi-Fi adapter is facing you.
  5. Nikon COOLPIX P2 WiFi Card Replacement: step 5, image 1 of 3 Nikon COOLPIX P2 WiFi Card Replacement: step 5, image 2 of 3 Nikon COOLPIX P2 WiFi Card Replacement: step 5, image 3 of 3
    • Using a plastic opening tool, pry the front casing of the camera.
    • Continue this motion all around the front casing of the camera.
    • Gently pull apart the front casing from the rest of the camera.
  6. Nikon COOLPIX P2 WiFi Card Replacement: step 6, image 1 of 1
    • Using the plastic opening tool pry the back casing of the camera.
  7. Nikon COOLPIX P2 WiFi Card Replacement: step 7, image 1 of 1
    • Orange ribbon is fragile
    • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
  8. Nikon COOLPIX P2 WiFi Card Replacement: step 8, image 1 of 2 Nikon COOLPIX P2 WiFi Card Replacement: step 8, image 2 of 2
    • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
    • Pull apart the orange ribbon and front casing from the rest of the camera.
  9. Nikon COOLPIX P2 WiFi Card Replacement, LCD Screen: step 9, image 1 of 2 Nikon COOLPIX P2 WiFi Card Replacement, LCD Screen: step 9, image 2 of 2
    • Use plastic opening tool to carefully pry the LCD Screen from the camera.
  10. Nikon COOLPIX P2 WiFi Card Replacement: step 10, image 1 of 2 Nikon COOLPIX P2 WiFi Card Replacement: step 10, image 2 of 2
    • Gently pull the ribbon cable down to release the latch, then pull up to remove it from the motherboard.
  11. Nikon COOLPIX P2 WiFi Card Replacement: step 11, image 1 of 1
  12. Nikon COOLPIX P2 WiFi Card Replacement, WiFi Card: step 12, image 1 of 1
    • Continue by removing two screws from the back of the camera body.
  13. Nikon COOLPIX P2 WiFi Card Replacement: step 13, image 1 of 1
    • Remove the screw connecting the wifi card cover to the front of the camera.
  14. Nikon COOLPIX P2 WiFi Card Replacement: step 14, image 1 of 1
    • Remove the final screw connecting the Wifi card cover to the case.
  15. Nikon COOLPIX P2 WiFi Card Replacement: step 15, image 1 of 1
    • Gently pull the Wifi card cover off of the camera body.
  16. Nikon COOLPIX P2 WiFi Card Replacement: step 16, image 1 of 1
    • Remove the screw holding the Wifi Card to the camera body.
  17. Nikon COOLPIX P2 WiFi Card Replacement: step 17, image 1 of 1
    • Gently pull the WiFi card out of the camera.
2 other people completed this guide.
Joshua Avery
31 Reputation
3 Guides authored
Cal Poly, Team 3-28, Amido Winter 2012 Member of Cal Poly, Team 3-28, Amido Winter 2012
CPSU-AMIDO-W12S3G28
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 911
