Nikon COOLPIX P500 Rear Case Replacement
Kevin Scott
Kevin Scott and 5 other contributors
Last updated on July 9, 2020
10 - 20 minutes
Moderate
Needs Better Images
Introduction
Go to step 1
This is a guide that demonstrates how to isolate the rear case of your camera from the rest of the device.
Tools
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Nikon COOLPIX P500 Rear Case Replacement, Battery: step 1, image 1 of 2 Nikon COOLPIX P500 Rear Case Replacement, Battery: step 1, image 2 of 2
    • Electric shock is a huge risk if the battery is not removed while taking the camera apart.
    • Press down and forward on the battery cover latch.
    • Push the orange latch, in the direction of the arrow on it, to release the battery.
  2. Nikon COOLPIX P500 Rear Case Replacement, Rear Case: step 2, image 1 of 3 Nikon COOLPIX P500 Rear Case Replacement, Rear Case: step 2, image 2 of 3 Nikon COOLPIX P500 Rear Case Replacement, Rear Case: step 2, image 3 of 3
    • Remove the marked 3mm screws.
    • Separate the two parts of the body of the camera slightly.
    • Make sure not to pull too hard because there are connector ribbons.
    • Detach the connector ribbons before fully separating the camera into two pieces.
  3. Nikon COOLPIX P500 Rear Case Replacement: step 3, image 1 of 1
    • Remove the labeled 3mm screws using a PH00 screwdriver.
  4. Nikon COOLPIX P500 Rear Case Replacement: step 4, image 1 of 1
    • Remove the brown metal plate.
Kevin Scott
517 Reputation
3 Guides authored
Cal Poly, Team 19-10, Maness Winter 2015 Member of Cal Poly, Team 19-10, Maness Winter 2015
CPSU-MANESS-W15S19G10
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 12
All Time: 1,094
