Nikon COOLPIX P600 Battery Replacement
Geronimo Gutierrez IV
Geronimo Gutierrez IV and 3 other contributors
Last updated on June 17, 2024
30 seconds
Very easy
Introduction
Go to step 1
In this guide you will learn how to replace the Nikon COOLPIX P600 battery, in as little as three easy steps. The steps will include where the battery compartment is located, what the switch to the battery cover looks like, and how to remove the battery.
Additional Information
Nikon COOLPIX P600 Technical Specifications
Nikon COOLPIX P600 Service & Support
  1. Nikon COOLPIX P600 Battery Replacement, Battery: step 1, image 1 of 1
    • Turn the camera upside down so that the lens is facing away from you.
  2. Nikon COOLPIX P600 Battery Replacement: step 2, image 1 of 2 Nikon COOLPIX P600 Battery Replacement: step 2, image 2 of 2
    • Slide the switch on the battery cover towards the center of the camera.
  3. Nikon COOLPIX P600 Battery Replacement: step 3, image 1 of 2 Nikon COOLPIX P600 Battery Replacement: step 3, image 2 of 2
    • Once the battery cover is open, push the solid yellow tab in the direction of the arrow. This will then eject the battery out of the camera.
To reassemble your device, follow these instructions in reverse order. Make sure the battery is pushed back into the battery compartment enough to have the yellow latch seen in step three click back over the top of the battery before attempting to close the battery cover.
Attached Documents
354 Reputation
2 Guides authored
CSU Fullerton, Team 1-5, Bruce Fall 2015 Member of CSU Fullerton, Team 1-5, Bruce Fall 2015
CSUF-BRUCE-F15S1G5
3 Members
9 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 50
All Time: 2,363
