Nikon COOLPIX P7700 Back Casing Replacement
  1. Nikon COOLPIX P7700 Back Casing Replacement, Back Casing: step 1, image 1 of 2 Nikon COOLPIX P7700 Back Casing Replacement, Back Casing: step 1, image 2 of 2
    • Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
    • Remove the side panel.
  2. Nikon COOLPIX P7700 Back Casing Replacement: step 2, image 1 of 1
    • Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
  3. Nikon COOLPIX P7700 Back Casing Replacement: step 3, image 1 of 1
    • Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
  4. Nikon COOLPIX P7700 Back Casing Replacement: step 4, image 1 of 1
    • Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
  5. Nikon COOLPIX P7700 Back Casing Replacement: step 5, image 1 of 1
    • Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
  6. Nikon COOLPIX P7700 Back Casing Replacement: step 6, image 1 of 2 Nikon COOLPIX P7700 Back Casing Replacement: step 6, image 2 of 2
    • Begin separating the camera into two parts.
    • It is okay to remove the orange ribbon. This will be easily put back into place when re-assembling.
  7. Nikon COOLPIX P7700 Back Casing Replacement: step 7, image 1 of 1
    • Remove the back casing.
2 other people completed this guide.
Dustin Wahl
808 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 2,112
