Nikon COOLPIX P7700 Focusing Screen Replacement
  1. Nikon COOLPIX P7700 Focusing Screen Replacement, Back Casing: step 1, image 1 of 2 Nikon COOLPIX P7700 Focusing Screen Replacement, Back Casing: step 1, image 2 of 2
    • Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
    • Remove the side panel.
  2. Nikon COOLPIX P7700 Focusing Screen Replacement: step 2, image 1 of 1
    • Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
  3. Nikon COOLPIX P7700 Focusing Screen Replacement: step 3, image 1 of 1
    • Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
  4. Nikon COOLPIX P7700 Focusing Screen Replacement: step 4, image 1 of 1
    • Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
  5. Nikon COOLPIX P7700 Focusing Screen Replacement: step 5, image 1 of 1
    • Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
  6. Nikon COOLPIX P7700 Focusing Screen Replacement: step 6, image 1 of 2 Nikon COOLPIX P7700 Focusing Screen Replacement: step 6, image 2 of 2
    • Begin separating the camera into two parts.
    • It is okay to remove the orange ribbon. This will be easily put back into place when re-assembling.
  7. Nikon COOLPIX P7700 Focusing Screen Replacement: step 7, image 1 of 1
    • Remove the back casing.
  8. Nikon COOLPIX P7700 Focusing Screen Replacement, Focusing Screen: step 8, image 1 of 1
    • Once the back casing is off, locate the 4.3 mm silver screw near the top of the camera and remove it using the Phillips #00 screwdriver.
  9. Nikon COOLPIX P7700 Focusing Screen Replacement: step 9, image 1 of 1
    • Remove the metal sheet from the camera.
    • It is okay to remove the orange ribbon from the camera.
  10. Nikon COOLPIX P7700 Focusing Screen Replacement: step 10, image 1 of 3 Nikon COOLPIX P7700 Focusing Screen Replacement: step 10, image 2 of 3 Nikon COOLPIX P7700 Focusing Screen Replacement: step 10, image 3 of 3
    • Remove the four 4.3 mm silver screws located on the ends of the chip using the Phillips #00 screwdriver.
  11. Nikon COOLPIX P7700 Focusing Screen Replacement: step 11, image 1 of 2 Nikon COOLPIX P7700 Focusing Screen Replacement: step 11, image 2 of 2
    • Remove the two 4.3 mm silver screws on the far right side of the camera using the Phillips #00 screwdriver.
  12. Nikon COOLPIX P7700 Focusing Screen Replacement: step 12, image 1 of 2 Nikon COOLPIX P7700 Focusing Screen Replacement: step 12, image 2 of 2
    • Lift and detach connector from board as shown.
  13. Nikon COOLPIX P7700 Focusing Screen Replacement: step 13, image 1 of 1
    • Remove the board from the camera to locate lens opening
  14. Nikon COOLPIX P7700 Focusing Screen Replacement: step 14, image 1 of 1
    • Remove the 4.3 mm screws from the metal sheet using the Phillips #00 screwdriver.
  15. Nikon COOLPIX P7700 Focusing Screen Replacement: step 15, image 1 of 1
    • Lift the metal sheet up and out of the camera.
  16. Nikon COOLPIX P7700 Focusing Screen Replacement: step 16, image 1 of 1
    • Locate the reflective lens.
  17. Nikon COOLPIX P7700 Focusing Screen Replacement: step 17, image 1 of 1
    • Remove the lens from the camera.
2 other people completed this guide.
Dustin Wahl
775 Reputation
4 Guides authored
2 Comments
Hey I have a P7700 that shows a lens error and focusing doesn't work.
I took it apart and removed the focus motor and it seems that the focus lens moves as it should but when turning it on the picture will be blurry for a second until the lens error comes up.
What issue is fixed by replacing this focus lens?
Dominik Bessler - Reply
Hello.
Do you have a service procedure to fix the exposure dial in this camera?
Hugo - Reply
Past 24 Hours: 7
Past 7 Days: 14
Past 30 Days: 29
All Time: 1,783
