Nikon COOLPIX S3600 SD Card Replacement
Lenisha Poirier
Lenisha Poirier and 5 other contributors
Last updated on July 26, 2020
2 minutes
Very easy
Introduction
Go to step 1
If your camera is not saving pictures, you may need to remove or replace the memory card. Follow this replacement guide for help!
  1. Nikon COOLPIX S3600 SD Card Replacement, SD Card: step 1, image 1 of 2 Nikon COOLPIX S3600 SD Card Replacement, SD Card: step 1, image 2 of 2
    • Push latch downwards to open the battery hatch located on the bottom right.
    • Memory card is located above the battery compartment.
  2. Nikon COOLPIX S3600 SD Card Replacement: step 2, image 1 of 3 Nikon COOLPIX S3600 SD Card Replacement: step 2, image 2 of 3 Nikon COOLPIX S3600 SD Card Replacement: step 2, image 3 of 3
    • Push in the memory card until you can't push it in any more and release.
    • Memory card should be slightly popped up.
    • Now you can carefully remove the memory card.
Lenisha Poirier
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 39
All Time: 3,676
