Nikon CoolPix S5 Buttons Replacement
  1. Nikon CoolPix S5 Buttons Replacement, Back Cover: step 1, image 1 of 1
    • Remove the wristlet by untying the strap.
  2. Nikon CoolPix S5 Buttons Replacement: step 2, image 1 of 1
    • Open the SD/Battery cover.
  3. Nikon CoolPix S5 Buttons Replacement: step 3, image 1 of 2 Nikon CoolPix S5 Buttons Replacement: step 3, image 2 of 2
    • Remove the four screws adjacent to the SD/battery opening using a Phillips #00 screwdriver.
  4. Nikon CoolPix S5 Buttons Replacement: step 4, image 1 of 2 Nikon CoolPix S5 Buttons Replacement: step 4, image 2 of 2
    • Remove the side paneling of the camera by prying it off with your hands.
  5. Nikon CoolPix S5 Buttons Replacement: step 5, image 1 of 2 Nikon CoolPix S5 Buttons Replacement: step 5, image 2 of 2
    • Start on the wristlet side of the camera and use the #00 Phillips screwdriver to remove the two screws that hold the backplate in place.
    • Repeat the removal of the two screws on the other side of the camera.
  6. Nikon CoolPix S5 Buttons Replacement: step 6, image 1 of 2 Nikon CoolPix S5 Buttons Replacement: step 6, image 2 of 2
    • Separate the back faceplate from the rest of the camera.
  7. Nikon CoolPix S5 Buttons Replacement, Buttons: step 7, image 1 of 1
    • The plate holding the buttons is on the right side of the camera. Use your fingers to open it to the right, away from the LCD screen. Do not twist or force the panel open. It should lift easily.
  8. Nikon CoolPix S5 Buttons Replacement: step 8, image 1 of 1
    • Pull on ribbon cables to disconnect ribbon cables.
3 other people completed this guide.
Patty Richeson
99 Reputation
4 Guides authored
Clemson, Team 12-5, Benson Spring 2013 Member of Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 9
All Time: 632
