Nikon CoolPix S600 Lens Assembly Replacement
  1. Nikon CoolPix S600 Lens Assembly Replacement, Front and Rear Casing: step 1, image 1 of 1
    • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  2. Nikon CoolPix S600 Lens Assembly Replacement: step 2, image 1 of 1
    • Remove the chrome side cover from the body of the camera.
  3. Nikon CoolPix S600 Lens Assembly Replacement: step 3, image 1 of 1
    • Remove the four 3.2 mm screws on the bottom of the camera.
  4. Nikon CoolPix S600 Lens Assembly Replacement: step 4, image 1 of 2 Nikon CoolPix S600 Lens Assembly Replacement: step 4, image 2 of 2
    • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
    • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
  5. Nikon CoolPix S600 Lens Assembly Replacement: step 5, image 1 of 2 Nikon CoolPix S600 Lens Assembly Replacement: step 5, image 2 of 2
    • Gently separate the back cover from the body of the camera.
    • The back casing will still be connected to the circuit board by a ribbon
  6. Nikon CoolPix S600 Lens Assembly Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Use the tweezers to disconnect the ribbon from the circuit board.
  7. Nikon CoolPix S600 Lens Assembly Replacement: step 7, image 1 of 1
    • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
  8. Nikon CoolPix S600 Lens Assembly Replacement: step 8, image 1 of 2 Nikon CoolPix S600 Lens Assembly Replacement: step 8, image 2 of 2
    • Gently separate the front cover from the body of the camera.
    • The front casing will still be connected to the circuit board by a few wires
  9. Nikon CoolPix S600 Lens Assembly Replacement: step 9, image 1 of 1
    • Remove the two 3.2 mm screws that hold the flash to the front cover.
  10. Nikon CoolPix S600 Lens Assembly Replacement: step 10, image 1 of 3 Nikon CoolPix S600 Lens Assembly Replacement: step 10, image 2 of 3 Nikon CoolPix S600 Lens Assembly Replacement: step 10, image 3 of 3
    • Use the Spudger to remove the copper colored light bulb clip.
    • Remove the front cover entierly from the camera body.
  11. Nikon CoolPix S600 Lens Assembly Replacement, Lens Assembly: step 11, image 1 of 2 Nikon CoolPix S600 Lens Assembly Replacement, Lens Assembly: step 11, image 2 of 2
    • From the top view of the camera, remove the one 5.8 mm screw.
    • From the top view of the camera, remove the one 2.8 mm screw
  12. Nikon CoolPix S600 Lens Assembly Replacement: step 12, image 1 of 1
    • Remove the three 3.4 mm screws from the back side of the camera.
  13. Nikon CoolPix S600 Lens Assembly Replacement: step 13, image 1 of 1
    • Remove the two 3.4 mm screws from the side of the camera.
  14. Nikon CoolPix S600 Lens Assembly Replacement: step 14, image 1 of 1
    • Separate the two metal body pieces from the rest of the camera.
  15. Nikon CoolPix S600 Lens Assembly Replacement: step 15, image 1 of 2 Nikon CoolPix S600 Lens Assembly Replacement: step 15, image 2 of 2
    • Gently remove the two ribbons connecting the lens to the mother board.
  16. Nikon CoolPix S600 Lens Assembly Replacement: step 16, image 1 of 2 Nikon CoolPix S600 Lens Assembly Replacement: step 16, image 2 of 2
    • Gently separate the camera lens from the mother board.
2 other people completed this guide.
andreas anggasastra
116 Reputation
5 Guides authored
Cuesta, Team 1-6, Zipperian Fall 2011 Member of Cuesta, Team 1-6, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G6
2 Members
6 Guides authored
One Comment
Any place where I could buy a new lens for the camera nowadays?
thesilver - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 3,263
