Nikon Coolpix 3500 LCD Screen Replacement
  1. Nikon Coolpix 3500 LCD Screen Replacement, Battery: step 1, image 1 of 1
    • Unlatch the battery cover and slide the cover out. Place cover to the side, it will not be needed for the next few steps.
    • Remove the battery.
    • Remove the battery cover without using excessive force. Keep in mind this cover is fragile.
  2. Nikon Coolpix 3500 LCD Screen Replacement, Front Cover: step 2, image 1 of 1
    • Remove the two 4.5 mm screws that sit next to the battery slot.
    • Remove the 3 mm screw that sits below the CF card slot.
    • Remove the 4.5 mm screw that sits above the digital I/O cover.
  3. Nikon Coolpix 3500 LCD Screen Replacement: step 3, image 1 of 1
    • Remove the two 4.5 mm screws that sit inside the battery slot.
  4. Nikon Coolpix 3500 LCD Screen Replacement: step 4, image 1 of 1
    • Remove the two 5 mm screws that sit near the camera strap eyelet.
    • Remove the camera strap eyelet.
  5. Nikon Coolpix 3500 LCD Screen Replacement: step 5, image 1 of 1
    • Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
  6. Nikon Coolpix 3500 LCD Screen Replacement: step 6, image 1 of 2 Nikon Coolpix 3500 LCD Screen Replacement: step 6, image 2 of 2
    • Remove the five 3.5 mm screws that sit at the bottom of the camera.
    • Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
    • Do not apply too much force; two wires still connect the front cover to the motherboard.
  7. Nikon Coolpix 3500 LCD Screen Replacement: step 7, image 1 of 2 Nikon Coolpix 3500 LCD Screen Replacement: step 7, image 2 of 2
    • Using a spudger, detach the white-capped wire.
    • Using a spudger, detach the orange-capped wire and set the front cover aside.
  8. Nikon Coolpix 3500 LCD Screen Replacement, Motherboard: step 8, image 1 of 1
    • Detach the grey-capped wire found near the edge of the board.
    • Located next to the blue wires is a green chip. Detach that green chip.
  9. Nikon Coolpix 3500 LCD Screen Replacement: step 9, image 1 of 2 Nikon Coolpix 3500 LCD Screen Replacement: step 9, image 2 of 2
    • Remove the 3.5 mm screw that sits next to the rotating lens.
    • You will find that the motherboard is mobile. Flip, or invert the motherboard. Be cautious of the orange and blue ribbon cables. They should still connect the board to the LCD screen.
  10. Nikon Coolpix 3500 LCD Screen Replacement: step 10, image 1 of 2 Nikon Coolpix 3500 LCD Screen Replacement: step 10, image 2 of 2
    • Detach the blue ribbon cable.
    • Using a spudger, detach the orange ribbon cable by pushing it out horizontally.
    • Detach the red-capped wire.
    • Lift the logic board and lens out of the back cover. Be sure that they are connected.
  11. Nikon Coolpix 3500 LCD Screen Replacement: step 11, image 1 of 1
    • Lift the black covering
    • Remove the orange ribbon cable that connects the lens to the logic board.
  12. Nikon Coolpix 3500 LCD Screen Replacement, LCD Screen: step 12, image 1 of 1
    • Remove the 2.5 mm screw.
    • Remove the two 3.4 mm screws.
    • Remove the two 4.4 mm screws.
  13. Nikon Coolpix 3500 LCD Screen Replacement: step 13, image 1 of 1
    • Remove the LCD screen.
    • Do not drop the three-button rubber piece. Remove it carefully.
richard guenther
183 Reputation
6 Guides authored
Cal Poly, Team 30-38, Garner Spring 2010 Member of Cal Poly, Team 30-38, Garner Spring 2010
CPSU-GARNER-S10S30G38
5 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 2,856
