Nikon Coolpix 5400 Battery Door Replacement
  1. Nikon Coolpix 5400 Battery Door Replacement, Battery Door: step 1, image 1 of 1
    • Remove one 3mm Phillips #0 screw from the top of the camera back cover.
  2. Nikon Coolpix 5400 Battery Door Replacement: step 2, image 1 of 1
    • Remove three 3mm Phillips #0 screws from the side of the back cover.
  3. Nikon Coolpix 5400 Battery Door Replacement: step 3, image 1 of 1
    • Lift memory card flap.
    • Remove one 3mm Phillips #0 screw from the side of the back case.
  4. Nikon Coolpix 5400 Battery Door Replacement: step 4, image 1 of 1
    • Remove four 3mm Phillips #0 screws from the bottom of the back case.
  5. Nikon Coolpix 5400 Battery Door Replacement: step 5, image 1 of 2 Nikon Coolpix 5400 Battery Door Replacement: step 5, image 2 of 2
    • Use a plastic opening tool to gently pop the back case away from the body of the camera.
    • Pull the back case away from the camera very gently.
    • The connecting cables are very fragile and easily broken.
  6. Nikon Coolpix 5400 Battery Door Replacement: step 6, image 1 of 1
    • Flip camera over so the bottom is facing up.
    • Push the sliding latch to open the battery door.
    • Push the press fit pin firmly with a flat-head screwdriver to release it from the hinge housing.
    • Push to the left, half the length of the pin.
  7. Nikon Coolpix 5400 Battery Door Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Grasp the press fit pin firmly with precision tweezers to pull it from the housing.
    • Do not to drop the pin into the camera body.
  8. Nikon Coolpix 5400 Battery Door Replacement: step 8, image 1 of 1
    • Remove the battery door by lifting it out of the camera body.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 259
