Nikon Coolpix 775 Motherboard Replacement
  1. Nikon Coolpix 775 Motherboard Replacement, Battery: step 1, image 1 of 3 Nikon Coolpix 775 Motherboard Replacement, Battery: step 1, image 2 of 3 Nikon Coolpix 775 Motherboard Replacement, Battery: step 1, image 3 of 3
    • Flip the camera, so the bottom is facing up.
  2. Nikon Coolpix 775 Motherboard Replacement: step 2, image 1 of 2 Nikon Coolpix 775 Motherboard Replacement: step 2, image 2 of 2
    • Slide the gray latch to the open "pac-man" symbol.
  3. Nikon Coolpix 775 Motherboard Replacement: step 3, image 1 of 3 Nikon Coolpix 775 Motherboard Replacement: step 3, image 2 of 3 Nikon Coolpix 775 Motherboard Replacement: step 3, image 3 of 3
    • Flip up the cover and remove the battery inside the slot.
  4. Nikon Coolpix 775 Motherboard Replacement, Motherboard: step 4, image 1 of 3 Nikon Coolpix 775 Motherboard Replacement, Motherboard: step 4, image 2 of 3 Nikon Coolpix 775 Motherboard Replacement, Motherboard: step 4, image 3 of 3
    • Unscrew the eight 4mm long JIS #00 screws from the bottom, right side, and the left side.
  5. Nikon Coolpix 775 Motherboard Replacement: step 5, image 1 of 3 Nikon Coolpix 775 Motherboard Replacement: step 5, image 2 of 3 Nikon Coolpix 775 Motherboard Replacement: step 5, image 3 of 3
    • Grab the camera with both your hand from the front and the back.
    • Pull the two parts apart.
    • You may have to pull at different angles to get the two parts to separate, but make sure you don't pull too hard because there is a wire connection on the inside.
  6. Nikon Coolpix 775 Motherboard Replacement: step 6, image 1 of 3 Nikon Coolpix 775 Motherboard Replacement: step 6, image 2 of 3 Nikon Coolpix 775 Motherboard Replacement: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Flip the camera back so you can see the top.
    • Pull the ribbon cable out of the socket connecting to the motherboard by using your hands or tweezers.
    • Be careful not to puncture or rip the ribbon cable.
  7. Nikon Coolpix 775 Motherboard Replacement: step 7, image 1 of 3 Nikon Coolpix 775 Motherboard Replacement: step 7, image 2 of 3 Nikon Coolpix 775 Motherboard Replacement: step 7, image 3 of 3
    • Look back to the top of the camera.
    • Flip up the tab that is exposed right by the dial using tweezers.
    • Release the ribbon to be able to separate the top part of the back of the camera.
    • Be careful not to rip the ribbon cable.
  8. Nikon Coolpix 775 Motherboard Replacement: step 8, image 1 of 3 Nikon Coolpix 775 Motherboard Replacement: step 8, image 2 of 3 Nikon Coolpix 775 Motherboard Replacement: step 8, image 3 of 3
    • Look at the top side of the camera.
    • Unscrew the two 4mm Phillips #00 screws.
    • Unscrew the 2mm JIS #00 screw as well.
  9. Nikon Coolpix 775 Motherboard Replacement: step 9, image 1 of 3 Nikon Coolpix 775 Motherboard Replacement: step 9, image 2 of 3 Nikon Coolpix 775 Motherboard Replacement: step 9, image 3 of 3
    • Push or slide the the top dial toward the backside of the camera to unclip from the motherboard.
  10. Nikon Coolpix 775 Motherboard Replacement: step 10, image 1 of 2 Nikon Coolpix 775 Motherboard Replacement: step 10, image 2 of 2
    • Pull the red and black wire out of the socket on the motherboard.
    • Pull motherboard up out of camera.
  11. Nikon Coolpix 775 Motherboard Replacement: step 11, image 1 of 3 Nikon Coolpix 775 Motherboard Replacement: step 11, image 2 of 3 Nikon Coolpix 775 Motherboard Replacement: step 11, image 3 of 3
    • Pull the ribbon connected to the dial off the motherboard.
Suketu Patel
303 Reputation
2 Guides authored
IUPUI, Team S2-G3, Baechle Fall 2018 Member of IUPUI, Team S2-G3, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G3
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 269
