Nikon Coolpix A900 Battery Replacement
Andres Aronstam
Andres Aronstam and 3 other contributors
Last updated on June 16, 2020
2 minutes
Very easy
Introduction
Go to step 1
This guide is for the user of the Nikon Coolpix A900 camera. As the Nikon Coolpix A900 camera is used, the battery will need to be taken out for either charging or replacement. This can be noted by the user if the camera will not turn on, or if the camera displays a message stating that the battery needs to be charged.
When this time comes, this guide can be used to locate the battery and to help with the removal process. Removing the battery allows it to be recharged and replaced so the camera can be used again.
  1. Nikon Coolpix A900 Battery Replacement, Battery: step 1, image 1 of 1
    • Orient the camera so that it is upside down, with the lens facing towards you.
  2. Nikon Coolpix A900 Battery Replacement: step 2, image 1 of 2 Nikon Coolpix A900 Battery Replacement: step 2, image 2 of 2
    • Slide the battery door lock left to unlock it.
    • The battery door will automatically open.
  3. Nikon Coolpix A900 Battery Replacement: step 3, image 1 of 2 Nikon Coolpix A900 Battery Replacement: step 3, image 2 of 2
    • Slide the yellow tab up to release the battery.
    • To re-insert a battery, slide the battery back in until the yellow tab locks it in place.
    • There is a diagram on the opposite side of the battery compartment to help you orient the battery correctly.
0 Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 21
All Time: 1,040
