Nikon Coolpix AW130 Battery Door Replacement
  1. Nikon Coolpix AW130 Battery Door Replacement, Battery: step 1, image 1 of 2 Nikon Coolpix AW130 Battery Door Replacement, Battery: step 1, image 2 of 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Battery Door Replacement: step 2, image 1 of 2 Nikon Coolpix AW130 Battery Door Replacement: step 2, image 2 of 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Battery Door Replacement: step 3, image 1 of 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Battery Door Replacement: step 4, image 1 of 2 Nikon Coolpix AW130 Battery Door Replacement: step 4, image 2 of 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Battery Door Replacement, Battery Door: step 5, image 1 of 2 Nikon Coolpix AW130 Battery Door Replacement, Battery Door: step 5, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the 2, 4mm screws on the underside of the camera.
  6. Nikon Coolpix AW130 Battery Door Replacement: step 6, image 1 of 1
    • Using the metal spudger, carefully pry on the plastic plate.
    • The plastic plate should begin to loosen. Completely remove it from the camera body.
  7. Nikon Coolpix AW130 Battery Door Replacement: step 7, image 1 of 2 Nikon Coolpix AW130 Battery Door Replacement: step 7, image 2 of 2
    • Open the battery door. Near the hinge, a pair of screws should now be exposed.
    • Using a Phillips #00 screwdriver, remove the 2, 4mm screws.
  8. Nikon Coolpix AW130 Battery Door Replacement: step 8, image 1 of 1
    • Pull the battery door away from the camera body.
6 Comments
Where can I purchase the battery cover?
Thanh Tran - Reply
Where can I buy the AW130 battery door?
Jose - Reply
I’m trying to replace the battery door. I removed the 2 bottom screws and loosened the plate as in Steps 5 and 6. How do I remove the plate without breaking it?
Jose - Reply
like jose I have removed the screws and loosened the plate but can’t figure out how to remove it. How do I get it out?
Marianne Chaffin Strickland - Reply
Need web site to order battery door?
Connie Mossor - Reply
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 27
All Time: 4,189
