Nikon Coolpix AW130 Front Panel Replacement
  1. Nikon Coolpix AW130 Front Panel Replacement, Battery: step 1, image 1 of 2 Nikon Coolpix AW130 Front Panel Replacement, Battery: step 1, image 2 of 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Front Panel Replacement: step 2, image 1 of 2 Nikon Coolpix AW130 Front Panel Replacement: step 2, image 2 of 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Front Panel Replacement: step 3, image 1 of 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Front Panel Replacement: step 4, image 1 of 2 Nikon Coolpix AW130 Front Panel Replacement: step 4, image 2 of 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Front Panel Replacement, Front Panel: step 5, image 1 of 2 Nikon Coolpix AW130 Front Panel Replacement, Front Panel: step 5, image 2 of 2
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
  6. Nikon Coolpix AW130 Front Panel Replacement: step 6, image 1 of 2 Nikon Coolpix AW130 Front Panel Replacement: step 6, image 2 of 2
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
6 other people completed this guide.
One Comment
Hello, has this front panel influence on cameras sealing function? Or is it only as shield against mechanical demage?
Slavomir - Reply
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,462
