Nikon Coolpix AW130 LCD Screen Replacement
  1. Nikon Coolpix AW130 LCD Screen Replacement, Battery: step 1, image 1 of 2 Nikon Coolpix AW130 LCD Screen Replacement, Battery: step 1, image 2 of 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 LCD Screen Replacement: step 2, image 1 of 2 Nikon Coolpix AW130 LCD Screen Replacement: step 2, image 2 of 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 LCD Screen Replacement: step 3, image 1 of 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 LCD Screen Replacement: step 4, image 1 of 2 Nikon Coolpix AW130 LCD Screen Replacement: step 4, image 2 of 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: step 5, image 1 of 2 Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: step 5, image 2 of 2
    • Using the T5 Torx screwdriver, remove all four 4mm screws.
  6. Nikon Coolpix AW130 LCD Screen Replacement: step 6, image 1 of 1
    • Using a Phillips #000 screwdriver, remove the single 3mm screw found inside the battery/charging compartment.
  7. Nikon Coolpix AW130 LCD Screen Replacement: step 7, image 1 of 1
    • Remove the upper cover (connected by glue) and unscrew the single Philips screw.
  8. Nikon Coolpix AW130 LCD Screen Replacement: step 8, image 1 of 2 Nikon Coolpix AW130 LCD Screen Replacement: step 8, image 2 of 2
    • Remove two Philips screws from the bottom cover, lift gently the cover and remove the single Philips screw under it.
  9. Nikon Coolpix AW130 LCD Screen Replacement: step 9, image 1 of 1
    • Carefully remove the back cover from the camera body.
  10. Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: step 10, image 1 of 3 Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: step 10, image 2 of 3 Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: step 10, image 3 of 3
    • Using a Phillips #000 screwdriver, remove all 11, 4mm screws on the LCD screen cover.
    • Two screws are located on the right.
    • The remaining screws are hidden behind a connector ribbon on the left.
  11. Nikon Coolpix AW130 LCD Screen Replacement: step 11, image 1 of 2 Nikon Coolpix AW130 LCD Screen Replacement: step 11, image 2 of 2
    • Pull the LCD screen from the plastic frame after removing all of the screws.
  12. Nikon Coolpix AW130 LCD Screen Replacement: step 12, image 1 of 1
    Tool used on this step:
    Buy
    • Using a pair of tweezers from the precision tweezer set, carefully remove the screen from the metal frame.
    • Since the tweezers could shatter the screen, causing for broken glass, exercise extreme caution.
8 Comments
Hi.
Where can you buy a replacement screen?
Ben - Reply
Hi.
my contact is josem6073@gmail.com
Thank you .
Jose Martins - Reply
Please add Torx T5 screwdriver at the tool needed, required at step 5
macreateur - Reply
Hi.
my contact is cpapacon@gmail.com
Thank you .
Costis Papaconstantinou - Reply
Hi.
my contact is Keithdurkan@gmail.com
Thank you .
Keith Durkan - Reply
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 15
All Time: 2,997
