Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement
  1. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Battery: step 1, image 1 of 2 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Battery: step 1, image 2 of 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: step 2, image 1 of 2 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: step 2, image 2 of 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: step 3, image 1 of 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: step 4, image 1 of 2 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: step 4, image 2 of 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Map/Wi-Fi/Action Buttons: step 5, image 1 of 3 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Map/Wi-Fi/Action Buttons: step 5, image 2 of 3 Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement, Map/Wi-Fi/Action Buttons: step 5, image 3 of 3
    • Using the spudger, pry the plastic button face from the camera body.
    • The sharp edges of the spudger could cut you or pierce an exposed battery.
  6. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers from the precision tweezer set, remove the buttons from the larger plastic piece.
  7. Nikon Coolpix AW130 Map/Wi-Fi/Action Buttons Replacement: step 7, image 1 of 1
    • Using tweezers from the precision tweezer set, remove the silicon backing from the buttons.
    • From there, the buttons should dislodge from their plastic casing.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 693
