Nikon Coolpix B700 Back Frame Assembly Replacement
Introduction
Go to step 1This guide shows how to remove the back frame assembly of the Nikon Coolpix B700 digital camera. This provides access to the internals of the device.
Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
Open the HDMI flap to remove a 5.5mm screw.
Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
While twisting, pry apart the shell to split the camera in half.
Place the pry tool under the black latch. Lift gently until the latch flips up.
Gently pull the ribbon away from the latch.
