Introduction
The LCD screen can be easily replaced without removing any other parts from the device. If the LCD screen is cracked or the backlight is inoperable, refer to this replacement guide.
Use a Phillips screwdriver to remove the two 3.5mm screws at the top and bottom of the LCD Screen.
Tool used on this step:Desoldering Pump$3.99
Use the solder gun and desolder the yellow and blue wires.
Use the jimmy and slide it in between the LCD screen and lift out the LCD Screen.
Bonjour,
Ce tutoriel est vraiment super,mais oú peut on trouver l'écran de rechange ? Ai commandé sur internet et pas reçu le même modèle
2 other people completed this guide.
2 Comments
Hi, I like the first 6 steps, but what are the rest of the steps?
