Nikon Coolpix E5700 Rear LCD Replacement
  1. Nikon Coolpix E5700 Rear LCD Replacement, Battery: step 1, image 1 of 2 Nikon Coolpix E5700 Rear LCD Replacement, Battery: step 1, image 2 of 2
    • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Open the battery door.
  2. Nikon Coolpix E5700 Rear LCD Replacement: step 2, image 1 of 1
    • Pull the battery out of the E5700.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Nikon Coolpix E5700 Rear LCD Replacement, Rear LCD: step 3, image 1 of 1
    • Remove two Phillips screws (3.4 mm) located on the left side of the screen.
  4. Nikon Coolpix E5700 Rear LCD Replacement: step 4, image 1 of 2 Nikon Coolpix E5700 Rear LCD Replacement: step 4, image 2 of 2
    • Remove two Phillips screws (3.4 mm) located on the right side of the screens.
  5. Nikon Coolpix E5700 Rear LCD Replacement: step 5, image 1 of 2 Nikon Coolpix E5700 Rear LCD Replacement: step 5, image 2 of 2
    • Remove back plastic monitor cover.
  6. Nikon Coolpix E5700 Rear LCD Replacement: step 6, image 1 of 1
    • Remove the Phillips screw on the top right side of the screen.
  7. Nikon Coolpix E5700 Rear LCD Replacement: step 7, image 1 of 1
    • Carefully unplug the grey bundle of wires in the white housing.
  8. Nikon Coolpix E5700 Rear LCD Replacement: step 8, image 1 of 1
    • Carefully unplug the small pink and wires in the grey housing.
  9. Nikon Coolpix E5700 Rear LCD Replacement: step 9, image 1 of 1
    • Remove the two Phillips screws on the left side of the screen.
  10. Nikon Coolpix E5700 Rear LCD Replacement: step 10, image 1 of 1
    • Remove the metal bar on the left side of the screen.
    • Remove the screen from the front plastic housing.
Kyle Sitton
351 Reputation
7 Guides authored
Cal Poly, Team 24-58, Amido Spring 2011 Member of Cal Poly, Team 24-58, Amido Spring 2011
CPSU-AMIDO-S11S24G58
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 2,399
