Nikon Coolpix L27 Screen Replacement
  1. Nikon Coolpix L27 Screen Replacement, Screen: step 1, image 1 of 3 Nikon Coolpix L27 Screen Replacement, Screen: step 1, image 2 of 3 Nikon Coolpix L27 Screen Replacement, Screen: step 1, image 3 of 3
    • Undo the latch at the bottom of the camera by pushing it to the side
    • Remove the batteries (and memory card if applicable)
  2. Nikon Coolpix L27 Screen Replacement: step 2, image 1 of 2 Nikon Coolpix L27 Screen Replacement: step 2, image 2 of 2
    • Remove the two 5 mm Phillips #000 screws from the left side.
  3. Nikon Coolpix L27 Screen Replacement: step 3, image 1 of 3 Nikon Coolpix L27 Screen Replacement: step 3, image 2 of 3 Nikon Coolpix L27 Screen Replacement: step 3, image 3 of 3
    • Lift the cover labeled "A/V OUT" to expose a hidden screw.
    • Remove two 5 mm Phillips #000 screws from the bottom of the camera.
  4. Nikon Coolpix L27 Screen Replacement: step 4, image 1 of 2 Nikon Coolpix L27 Screen Replacement: step 4, image 2 of 2
    • Remove the two 5 mm Phillips #000 screws from the right side of the camera.
  5. Nikon Coolpix L27 Screen Replacement: step 5, image 1 of 3 Nikon Coolpix L27 Screen Replacement: step 5, image 2 of 3 Nikon Coolpix L27 Screen Replacement: step 5, image 3 of 3
    • Carefully pry the back cover starting from the battery latch.
    • Once all sides are loose, lift the back cover up and off.
  6. Nikon Coolpix L27 Screen Replacement: step 6, image 1 of 1
    • Carefully lift the LCD screen up towards the bottom of the camera.
    • The LCD is connected to a cable so don't pull it out yet.
  7. Nikon Coolpix L27 Screen Replacement: step 7, image 1 of 1
    • Lightly push back the white switch holding in the screen cable
  8. Nikon Coolpix L27 Screen Replacement: step 8, image 1 of 2 Nikon Coolpix L27 Screen Replacement: step 8, image 2 of 2
    • Remove the cable from the camera.
    • Lift the screen out.
Vishalpreet Sandhu
157 Reputation
1 Guide authored
One Comment
would you know how to replace the little button battery just next to the screen, because the Lense is not retracting anymore?
Walter D. - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 19
All Time: 701
