Nikon Coolpix L32 LCD Replacement
  1. Nikon Coolpix L32 LCD Replacement, Front Panel: step 1, image 1 of 3 Nikon Coolpix L32 LCD Replacement, Front Panel: step 1, image 2 of 3 Nikon Coolpix L32 LCD Replacement, Front Panel: step 1, image 3 of 3
    • Remove the six(3.93mm screws) on the outside of the camera using a Phillips 00 screwdriver.
  2. Nikon Coolpix L32 LCD Replacement: step 2, image 1 of 1
    • Open the battery compartment door and pull the black back face apart from the front red face.
  3. Nikon Coolpix L32 LCD Replacement, LCD: step 3, image 1 of 1
    • Using the spudger, gently pull the LCD screen from the tray holding it.
    • Do not pull the LCD screen far from the camera because there is a ribbon cable connected to it.
  4. Nikon Coolpix L32 LCD Replacement: step 4, image 1 of 1
    • Use the spudger to lift up the small white retaining flap on the motherboard that is connected to the LCD screen's ribbon cable.
  5. Nikon Coolpix L32 LCD Replacement: step 5, image 1 of 1
    • With the small retaining white flap up, remove the LCD screen ribbon cable from the motherboard by sliding it out.
Sherika Jacobs
348 Reputation
3 Guides authored
USF Tampa, Team 2-4, Blackwell Fall 2016 Member of USF Tampa, Team 2-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G4
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 822
