Nikon Coolpix L320 LCD Replacement
  1. Nikon Coolpix L320 LCD Replacement, Batteries: step 1, image 1 of 2 Nikon Coolpix L320 LCD Replacement, Batteries: step 1, image 2 of 2
    • Flip the camera over to reveal the card/battery door.
    • Slide the button to the unlocked position and the door should pop open.
  2. Nikon Coolpix L320 LCD Replacement: step 2, image 1 of 2 Nikon Coolpix L320 LCD Replacement: step 2, image 2 of 2
    • Take out the old batteries.
    • Look at the yellow sticker inside of the the battery compartment. You'll see the symbol for the direction the new battery should face when replaced.
    • The “+” means to put the raised end facing up. The “-“ means to put the flat end up.
  3. Nikon Coolpix L320 LCD Replacement, LCD: step 3, image 1 of 3 Nikon Coolpix L320 LCD Replacement, LCD: step 3, image 2 of 3 Nikon Coolpix L320 LCD Replacement, LCD: step 3, image 3 of 3
    • Use a JIS screwdriver to remove seven screws from the frame of camera.
  4. Nikon Coolpix L320 LCD Replacement: step 4, image 1 of 1
    • Use an opening tool or spudger to separate the front and back of the camera.
  5. Nikon Coolpix L320 LCD Replacement: step 5, image 1 of 1
    • Use a JIS screwdriver to remove the screws connecting the LCD to the motherboard.
  6. Nikon Coolpix L320 LCD Replacement: step 6, image 1 of 1
    • Gently flip the LCD over to reveal a ribbon cable connected to the motherboard.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap of the ZIF connector. Then, you can safely pull the cable out.
    • Remove the LCD screen from the camera.
MollyHenderson
293 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 31
All Time: 162
