Nikon Coolpix L330 Image Sensor Replacement
  1. Nikon Coolpix L330 Image Sensor Replacement, Back Housing: step 1, image 1 of 3 Nikon Coolpix L330 Image Sensor Replacement, Back Housing: step 1, image 2 of 3 Nikon Coolpix L330 Image Sensor Replacement, Back Housing: step 1, image 3 of 3
    • There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
    • Two 1.5x2.5mm screws on the right side.
    • Two 1.5x2.5mm screws on the underside.
    • Two 1.5x2.5mm screw on the left side.
  2. Nikon Coolpix L330 Image Sensor Replacement: step 2, image 1 of 2 Nikon Coolpix L330 Image Sensor Replacement: step 2, image 2 of 2
    • After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
    • The metal spudger can damage the plastic housing, so use caution when applying any pressure to it. Use a plastic opening tool to reduce the risk of damage to the housing.
    • Remove the back housing of the camera by lifting it directly up.
    • The back cover may be slightly tight, therefore more force may be needed to lift it up.
  3. Nikon Coolpix L330 Image Sensor Replacement, LCD Screen: step 3, image 1 of 2 Nikon Coolpix L330 Image Sensor Replacement, LCD Screen: step 3, image 2 of 2
    • Insert the tips of your fingers into the space between the screen and back-plate.
    • Gently lift the screen up and out of the frame.
    • The screen is still held by a flexible display cable, therefore only lift the screen 0.5'' out of the back-plate.
  4. Nikon Coolpix L330 Image Sensor Replacement: step 4, image 1 of 2 Nikon Coolpix L330 Image Sensor Replacement: step 4, image 2 of 2
    • Tilt the screen so that the display cable forms a hinge with the backplate.
    • Rotate the display 180 degrees so that it faces you.
  5. Nikon Coolpix L330 Image Sensor Replacement: step 5, image 1 of 3 Nikon Coolpix L330 Image Sensor Replacement: step 5, image 2 of 3 Nikon Coolpix L330 Image Sensor Replacement: step 5, image 3 of 3
    • The display cable has a ZIF (zero insertion force) connector on the end. This has a tab that has to be pushed out before the cable can be safely removed.
    • Using a plastic opening tool or fingernail, pop up the black clip holding the display cable. This will release the cable.
    • Slide the display cable out of the connector.
    • The display cable can be damaged due to excessive bending, therefore avoid putting unnecessary strain on it.
  6. Nikon Coolpix L330 Image Sensor Replacement, Motherboard: step 6, image 1 of 1
    • Remove the screws from the silver back-plate with a PH000 screw head.
    • Two 1.5x2.5mm screws on the left side.
    • One 1.5x2.5mm screw on the right side.
  7. Nikon Coolpix L330 Image Sensor Replacement: step 7, image 1 of 1
    • The marked red box contains a highly charged capacitor. Check the charge using a voltmeter and discharge it first before continuing. Discharge capacitor guide.
    • Remove the screws holding the motherboard with a PH000 screw head.
  8. Nikon Coolpix L330 Image Sensor Replacement: step 8, image 1 of 1
    • Using a plastic opening tool or fingernail, pop up the black clips holding the ribbon cables. This will release the cables.
    • Slide the ribbon cables out of the connectors.
  9. Nikon Coolpix L330 Image Sensor Replacement: step 9, image 1 of 3 Nikon Coolpix L330 Image Sensor Replacement: step 9, image 2 of 3 Nikon Coolpix L330 Image Sensor Replacement: step 9, image 3 of 3
    • Remove the black sticker covering the electrical connections.
    • Desolder the eight wires from the motherboard.
  10. Nikon Coolpix L330 Image Sensor Replacement: step 10, image 1 of 3 Nikon Coolpix L330 Image Sensor Replacement: step 10, image 2 of 3 Nikon Coolpix L330 Image Sensor Replacement: step 10, image 3 of 3
    • Insert a plastic opening tool into the marked position. Push the tool towards the right to release the clip.
    • Using a thumb and forefinger, push the plastic cover up until it is at a 45 degree angle.
    • Pull the cover back and up to release it.
  11. Nikon Coolpix L330 Image Sensor Replacement: step 11, image 1 of 2 Nikon Coolpix L330 Image Sensor Replacement: step 11, image 2 of 2
    • The motherboard is still held in place by soldered connections.
    • Carefully desolder the connections .
    • The front cover has been removed in this picture, however the procedure is still the same.
  12. Nikon Coolpix L330 Image Sensor Replacement: step 12, image 1 of 1
    • Remove the motherboard by lifting it directly up.
  13. Nikon Coolpix L330 Image Sensor Replacement, Image Sensor: step 13, image 1 of 2 Nikon Coolpix L330 Image Sensor Replacement, Image Sensor: step 13, image 2 of 2
    • Remove the three 1.5x2.5mm screws using a PH000 screw head.
  14. Nikon Coolpix L330 Image Sensor Replacement: step 14, image 1 of 2 Nikon Coolpix L330 Image Sensor Replacement: step 14, image 2 of 2
    • Remove the three 1.5x1.75mm screws holding the lens in place using a PH000 screw head.
    • Lift the image sensor up and out of the bracket.
Rajeev
596 Reputation
4 Guides authored
USF Tampa, Team 2-10, Cagle Spring 2016 Member of USF Tampa, Team 2-10, Cagle Spring 2016
USFT-CAGLE-S16S2G10
4 Members
14 Guides authored
One Comment
In Step 11, there is one board right? I need that board. May I know where to purchase that board?
CJ Ramki - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 833
