Introduction
Follow this guide to replace a cracked or not working LCD screen for the Coolpix L340.
Remove two 5 mm Philips #000 screws on the left hand side of the camera located on the side where the batteries are inserted.
Remove two 5 mm Philips #000 screws on the bottom of the camera.
Remove two 5 mm Philips #000 screws on the left hand side of the camera located near the power button.
To remove the old LCD screen from the motherboard, there is an off-white ribbon on the motherboard that, the thin black ZIF (Zero Insertion Force) connector that needs to be lifted up so that the circuit piece connected to the LCD screen can be pulled out.
2 Comments
Is there a plastic cover as part of the rear cover on the L340? Trying to determine what exactly is cracked
Very helpful. Thanks
