Nikon Coolpix L610 Control Panel Replacement
  1. Nikon Coolpix L610 Control Panel Replacement, Plastic Cover: step 1, image 1 of 2 Nikon Coolpix L610 Control Panel Replacement, Plastic Cover: step 1, image 2 of 2
    • Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
  2. Nikon Coolpix L610 Control Panel Replacement: step 2, image 1 of 1
    • Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
    • Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
  3. Nikon Coolpix L610 Control Panel Replacement: step 3, image 1 of 1
    • Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
    • Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
  4. Nikon Coolpix L610 Control Panel Replacement: step 4, image 1 of 3 Nikon Coolpix L610 Control Panel Replacement: step 4, image 2 of 3 Nikon Coolpix L610 Control Panel Replacement: step 4, image 3 of 3
    • Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
  5. Nikon Coolpix L610 Control Panel Replacement, Control Panel: step 5, image 1 of 3 Nikon Coolpix L610 Control Panel Replacement, Control Panel: step 5, image 2 of 3 Nikon Coolpix L610 Control Panel Replacement, Control Panel: step 5, image 3 of 3
    • Carefully unscrew and remove the top and bottom (2.25 mm) screws from the control panel.
    • Carefully unscrew and remove the middle (3.20 mm) screws from the control panel.
  6. Nikon Coolpix L610 Control Panel Replacement: step 6, image 1 of 1
    • Carefully remove the ribbon connecting the control panel to the camera. The latch can be removed by sliding it down and pulling the ribbon down.
Jeremy
1,027 Reputation
5 Guides authored
USF Tampa, Team 9-4, Brown Winter 2015 Member of USF Tampa, Team 9-4, Brown Winter 2015
USFT-BROWN-W15S9G4
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 554
