Nikon Coolpix L820 LCD Replacement
  1. Nikon Coolpix L820 LCD Replacement, Settings Buttons: step 1, image 1 of 3 Nikon Coolpix L820 LCD Replacement, Settings Buttons: step 1, image 2 of 3 Nikon Coolpix L820 LCD Replacement, Settings Buttons: step 1, image 3 of 3
    • Remove the battery before beginning.
    • Use a Phillips #0 screwdriver to remove the screws on the front casing. There are ten screws, three on the left side, two on the bottom, and one on the right side of the camera.
  2. Nikon Coolpix L820 LCD Replacement: step 2, image 1 of 2 Nikon Coolpix L820 LCD Replacement: step 2, image 2 of 2
    • Remove the front top Phillips screw with the screwdriver.
    • Open the empty battery slot on the bottom of the camera, revealing four additional screws.
    • Unscrew the four Phillips screws with the screwdriver.
  3. Nikon Coolpix L820 LCD Replacement: step 3, image 1 of 3 Nikon Coolpix L820 LCD Replacement: step 3, image 2 of 3 Nikon Coolpix L820 LCD Replacement: step 3, image 3 of 3
    • Using the spudger, move around the casing, carefully separating the rear housing from the camera assembly.
    • Be sure to only apply pressure to the casing panels and not the sensitive internal electronics.
    • Once the rear housing is separated, the settings buttons will be accessible for replacement.
  4. Nikon Coolpix L820 LCD Replacement, LCD screen: step 4, image 1 of 3 Nikon Coolpix L820 LCD Replacement, LCD screen: step 4, image 2 of 3 Nikon Coolpix L820 LCD Replacement, LCD screen: step 4, image 3 of 3
    • Remove the front casing to expose the LCD screen and wires.
    • Do not damage the exposed wires.
  5. Nikon Coolpix L820 LCD Replacement: step 5, image 1 of 3 Nikon Coolpix L820 LCD Replacement: step 5, image 2 of 3 Nikon Coolpix L820 LCD Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Using the tweezers, lift the hinges connecting the two ribbon wires to the camera.
  6. Nikon Coolpix L820 LCD Replacement: step 6, image 1 of 2 Nikon Coolpix L820 LCD Replacement: step 6, image 2 of 2
    • Once the flexible ribbon wires are disconnected, remove the LCD screen.
2 other people completed this guide.
Lucas Otto
107 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 23
All Time: 2,383
