Nikon Coolpix L840 Motherboard Replacement
  1. Nikon Coolpix L840 Motherboard Replacement, Motherboard: step 1, image 1 of 3 Nikon Coolpix L840 Motherboard Replacement, Motherboard: step 1, image 2 of 3 Nikon Coolpix L840 Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
  2. Nikon Coolpix L840 Motherboard Replacement: step 2, image 1 of 1
    • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
    • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
  3. Nikon Coolpix L840 Motherboard Replacement: step 3, image 1 of 2 Nikon Coolpix L840 Motherboard Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
    • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
3 other people completed this guide.
Abraham Lozano
595 Reputation
4 Guides authored
Cal Poly, Team 1-11, Maness Spring 2016 Member of Cal Poly, Team 1-11, Maness Spring 2016
CPSU-MANESS-S16S1G11
4 Members
10 Guides authored
2 Comments
I was trying to find how to replace the CCD lens sensor on the Nikon Coolpix L840
waynelguyton - Reply
My camera display will work for a bit, but then goes off. Subsequent efforts to start it yield poor results. If I pick it up and try again in a few hours, I may have a short time to work before the screen goes dark. The batteries are new. I think this might be a case of blown capacitors on board, but I could use insight. The motherboard costs more than the camera now.
Stephen Scanlan - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 28
All Time: 2,048
