Nikon Coolpix P100 Motherboard Access
  1. Nikon Coolpix P100  Motherboard Access, Nikon Coolpix P100  Motherboard Access: step 1, image 1 of 1
    • Turn the front of the camera toward you.
  2. Nikon Coolpix P100  Motherboard Access: step 2, image 1 of 3 Nikon Coolpix P100  Motherboard Access: step 2, image 2 of 3 Nikon Coolpix P100  Motherboard Access: step 2, image 3 of 3
    • On the left side of the camera, use a Phillips #00 Precision Screwdriver to remove the two marked screws.
  3. Nikon Coolpix P100  Motherboard Access: step 3, image 1 of 1
    • On the right side of the camera, remove the first visible screw above the HDMI and A/V OUT cover.
  4. Nikon Coolpix P100  Motherboard Access: step 4, image 1 of 1
    • Lift the HDMI and A/V OUT cover to access the hidden screw between the two ports.
    • Remove the screw
  5. Nikon Coolpix P100  Motherboard Access: step 5, image 1 of 1
    • Flip the camera upside down and remove the seven marked screws.
  6. Nikon Coolpix P100  Motherboard Access: step 6, image 1 of 2 Nikon Coolpix P100  Motherboard Access: step 6, image 2 of 2
    • Turn the back of the camera toward you.
    • Lift the display panel and remove the two marked screws
  7. Nikon Coolpix P100  Motherboard Access: step 7, image 1 of 3 Nikon Coolpix P100  Motherboard Access: step 7, image 2 of 3 Nikon Coolpix P100  Motherboard Access: step 7, image 3 of 3
    • Use a plastic iFixit opening tool to gently loosen the top and sides of the camera.
  8. Nikon Coolpix P100  Motherboard Access: step 8, image 1 of 1
    • Before fully opening the camera, identify the two marked ribbon cables
    • Properly detach the ribbons before proceeding
  9. Nikon Coolpix P100  Motherboard Access: step 9, image 1 of 1
    • Carefully open the camera.
    • Now you have partial access to the camera's motherboard.
  10. Nikon Coolpix P100  Motherboard Access: step 10, image 1 of 1
    • Remove the five indicated screws that are attached to the metal plate.
  11. Nikon Coolpix P100  Motherboard Access: step 11, image 1 of 1
    • Remove the hidden top screw that is attached to the metal plate.
  12. Nikon Coolpix P100  Motherboard Access: step 12, image 1 of 1
    • Use a plastic iFixit opening tool to carefully loosen the metal plate.
    • Remove the metal plate to access the camera's motherboard.
  13. Nikon Coolpix P100  Motherboard Access: step 13, image 1 of 1
    • Now you have access to the camera's motherboard
Rikki Brown
267 Reputation
2 Guides authored
USF Tampa, Team 1-1, Tanski Winter 2015 Member of USF Tampa, Team 1-1, Tanski Winter 2015
USFT-TANSKI-W15S1G1
3 Members
8 Guides authored
One Comment
y como cambia el lente si se atasca
djalfonsodaza - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 28
All Time: 2,512
