Nikon Coolpix P100 Back Buttons Replacement
  1. Nikon Coolpix P100 Back Buttons Replacement, Back Buttons: step 1, image 1 of 1
    • Turn the front of the camera toward you.
  2. Nikon Coolpix P100 Back Buttons Replacement: step 2, image 1 of 3 Nikon Coolpix P100 Back Buttons Replacement: step 2, image 2 of 3 Nikon Coolpix P100 Back Buttons Replacement: step 2, image 3 of 3
    • On the left side of the camera, remove two screws using a Phillips #00 screwdriver.
  3. Nikon Coolpix P100 Back Buttons Replacement: step 3, image 1 of 1
    • On the right side of the camera, remove the first visible screw.
  4. Nikon Coolpix P100 Back Buttons Replacement: step 4, image 1 of 1
    • Lift the HDMI and A/V OUT cover to access the hidden screw.
  5. Nikon Coolpix P100 Back Buttons Replacement: step 5, image 1 of 1
    • Flip the camera upside down and remove the seven marked screws.
  6. Nikon Coolpix P100 Back Buttons Replacement: step 6, image 1 of 2 Nikon Coolpix P100 Back Buttons Replacement: step 6, image 2 of 2
    • Remove the two screws hidden underneath the display panel.
  7. Nikon Coolpix P100 Back Buttons Replacement: step 7, image 1 of 3 Nikon Coolpix P100 Back Buttons Replacement: step 7, image 2 of 3 Nikon Coolpix P100 Back Buttons Replacement: step 7, image 3 of 3
    • Use a plastic opening tool to gently loosen up the sides of the camera.
  8. Nikon Coolpix P100 Back Buttons Replacement: step 8, image 1 of 2 Nikon Coolpix P100 Back Buttons Replacement: step 8, image 2 of 2
    • Carefully open the camera.
    • There are two ribbon cables when opening the camera. Make sure to properly detach them before proceeding.
  9. Nikon Coolpix P100 Back Buttons Replacement: step 9, image 1 of 2 Nikon Coolpix P100 Back Buttons Replacement: step 9, image 2 of 2
    • This is the cover that houses the back buttons of the camera. Turn it around.
  10. Nikon Coolpix P100 Back Buttons Replacement: step 10, image 1 of 1
    • Remove the six indicated screws.
  11. Nikon Coolpix P100 Back Buttons Replacement: step 11, image 1 of 2 Nikon Coolpix P100 Back Buttons Replacement: step 11, image 2 of 2
    • Use a plastic opening tool to lift the metal plate and set it aside.
  12. Nikon Coolpix P100 Back Buttons Replacement: step 12, image 1 of 3 Nikon Coolpix P100 Back Buttons Replacement: step 12, image 2 of 3 Nikon Coolpix P100 Back Buttons Replacement: step 12, image 3 of 3
    • Turn the cover around and push against the buttons.
  13. Nikon Coolpix P100 Back Buttons Replacement: step 13, image 1 of 1
    • Now you have partial access to one set of buttons.
  14. Nikon Coolpix P100 Back Buttons Replacement: step 14, image 1 of 1
    • Find the last set of removal buttons on the bottom left.
  15. Nikon Coolpix P100 Back Buttons Replacement: step 15, image 1 of 1
    • Remove the screw.
  16. Nikon Coolpix P100 Back Buttons Replacement: step 16, image 1 of 2 Nikon Coolpix P100 Back Buttons Replacement: step 16, image 2 of 2
    • Use a plastic opening tool to remove the button.
Nghiem Ngo
330 Reputation
2 Guides authored
USF Tampa, Team 1-1, Tanski Winter 2015 Member of USF Tampa, Team 1-1, Tanski Winter 2015
USFT-TANSKI-W15S1G1
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 839
