Nikon Coolpix P100 Display Screen Replacement
  1. Nikon Coolpix P100 Display Screen Replacement, Display Screen: step 1, image 1 of 3 Nikon Coolpix P100 Display Screen Replacement, Display Screen: step 1, image 2 of 3 Nikon Coolpix P100 Display Screen Replacement, Display Screen: step 1, image 3 of 3
    • Flip the camera upside down so that the side with the serial number is face up.
    • Pull back the display panel. Orient the panel so that you are able to view the back of it.
  2. Nikon Coolpix P100 Display Screen Replacement: step 2, image 1 of 2 Nikon Coolpix P100 Display Screen Replacement: step 2, image 2 of 2
    • Remove the two screws closest to the piece connecting the panel to the camera with a Phillips #1 screwdriver.
  3. Nikon Coolpix P100 Display Screen Replacement: step 3, image 1 of 1
    • Remove the cover that was unscrewed in the last step.
  4. Nikon Coolpix P100 Display Screen Replacement: step 4, image 1 of 1
    • Remove the remaining four screws on the outermost corners of the panel using a Phillips #1 screwdriver.
  5. Nikon Coolpix P100 Display Screen Replacement: step 5, image 1 of 3 Nikon Coolpix P100 Display Screen Replacement: step 5, image 2 of 3 Nikon Coolpix P100 Display Screen Replacement: step 5, image 3 of 3
    • Use a plastic opening tool to pry open the back panel of the display screen.
  6. Nikon Coolpix P100 Display Screen Replacement: step 6, image 1 of 3 Nikon Coolpix P100 Display Screen Replacement: step 6, image 2 of 3 Nikon Coolpix P100 Display Screen Replacement: step 6, image 3 of 3
    • Carefully unhook the ribbon that attaches the panel to the camera.
    • Remove the top black panel cover.
  7. Nikon Coolpix P100 Display Screen Replacement: step 7, image 1 of 1
    • Remove the two screws on the panel that are closest to the ribbon cable using a Phillips #1 screwdriver.
  8. Nikon Coolpix P100 Display Screen Replacement: step 8, image 1 of 1
    • Remove the other two screws on the opposite side of the panel using a Phillips #1 screwdriver.
  9. Nikon Coolpix P100 Display Screen Replacement: step 9, image 1 of 2 Nikon Coolpix P100 Display Screen Replacement: step 9, image 2 of 2
    • Separate the metal portion of the screen from the plastic portion.
  10. Nikon Coolpix P100 Display Screen Replacement: step 10, image 1 of 2 Nikon Coolpix P100 Display Screen Replacement: step 10, image 2 of 2
    • Carefully remove the ribbon connector cable from the metal portion of the display.
    • Remove the display from the rest of the device.
5 other people completed this guide.
Rikki Brown
267 Reputation
2 Guides authored
USF Tampa, Team 1-1, Tanski Winter 2015 Member of USF Tampa, Team 1-1, Tanski Winter 2015
USFT-TANSKI-W15S1G1
3 Members
8 Guides authored
3 Comments
This guide help me to change my screen on Nikon P100 with out to much trouble, however I found step 7 unnecessary.
David Fyock - Reply
Hello, I've a problem during the re-mount of the display. Someone can help me? Thanks in advance! Mark
cwmark56 - Reply
I can't reconnect the connector on the step 10. Can you help me?
cwmark56 - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 29
All Time: 2,789
