Nikon Coolpix P510 LCD Replacement
Brian Hulsey
Brian Hulsey and 4 other contributors
Last updated on July 10, 2020
2 - 5 minutes
Easy
Introduction
Go to step 1
If you are having issues with your LCD, this guide will help you replace it with a minimal effort. This part is easy to get to, and easy to replace. Other than a screwdriver and a plastic opening tool, nothing else is needed to accomplish this.
Tools
Show more…
  1. Nikon Coolpix P510 LCD Replacement, Battery Removal: step 1, image 1 of 1
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 LCD Replacement: step 2, image 1 of 2 Nikon Coolpix P510 LCD Replacement: step 2, image 2 of 2
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
  3. Nikon Coolpix P510 LCD Replacement, LCD Screen Window: step 3, image 1 of 2 Nikon Coolpix P510 LCD Replacement, LCD Screen Window: step 3, image 2 of 2
    • Extend the LCD screen out and turn the camera upside down to get access to the screws on the bottom.
  4. Nikon Coolpix P510 LCD Replacement: step 4, image 1 of 2 Nikon Coolpix P510 LCD Replacement: step 4, image 2 of 2
    • Take the four 4mm PH00 Phillips screws out.
  5. Nikon Coolpix P510 LCD Replacement: step 5, image 1 of 2 Nikon Coolpix P510 LCD Replacement: step 5, image 2 of 2
    • Use a plastic opening tool to trace around the screen to pop the front and back section apart.
  6. Nikon Coolpix P510 LCD Replacement, LCD: step 6, image 1 of 2 Nikon Coolpix P510 LCD Replacement, LCD: step 6, image 2 of 2
    • Tilt the LCD up to get access to the back of it.
  7. Nikon Coolpix P510 LCD Replacement: step 7, image 1 of 2 Nikon Coolpix P510 LCD Replacement: step 7, image 2 of 2
    • Unplug the ribbon cables on the side of the chip under the LCD by simple pulling lightly on them.
  8. Nikon Coolpix P510 LCD Replacement: step 8, image 1 of 1
    • The chip has an adhesive on it to keep it attached to the LCD, and you will need to use a plastic opening tool to get it off.
    • It may take a little bit of pressure to get the chip off. Be gentle to make sure you don't break the chip.
6 other people completed this guide.
Brian Hulsey
1,506 Reputation
6 Guides authored
2 Comments
Esse LSD tem outro fita preta que conecta pode estar ruim
Leonardo Silva - Reply
Porque a minha não sei se ela é LCD ou esse negócio preto que conecta que tá ruim
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 34
All Time: 6,012
