Nikon Coolpix P510 Lens Casing Replacement
Brian Hulsey
Brian Hulsey and 2 other contributors
Last updated on July 11, 2020
No estimate
Moderate
Missing Details
Introduction
Go to step 1
This guide uses the lens assembly guide to get the camera apart. Once you have finished with the lens assembly, getting to the casing is fairly easy.
Tools
Show more…
  1. Nikon Coolpix P510 Lens Casing Replacement, Lens Assembly: step 1, image 1 of 2 Nikon Coolpix P510 Lens Casing Replacement, Lens Assembly: step 1, image 2 of 2
    • Flip the camera upside down and remove six 3mm PH00 Philips screws with a Philips screwdriver.
    • On the thumb grip, remove the one 4mm PH00 Philips screw.
  2. Nikon Coolpix P510 Lens Casing Replacement: step 2, image 1 of 1
    • With the camera upside down, remove the three 3mm PH00 Philips screws on the left side.
    • One of the screws are under the HDMI and A/V Out cover.
  3. Nikon Coolpix P510 Lens Casing Replacement: step 3, image 1 of 1
    • On the opposite side of the camera, remove the two 3mm PH00 Philips screws.
  4. Nikon Coolpix P510 Lens Casing Replacement: step 4, image 1 of 3 Nikon Coolpix P510 Lens Casing Replacement: step 4, image 2 of 3 Nikon Coolpix P510 Lens Casing Replacement: step 4, image 3 of 3
    • Open the flash and use a plastic opening tool to pop the tab under it as shown.
    • Now pull the casing apart.
    • The tripod attachment may fall out on its own, or you will need to pull it out.
  5. Nikon Coolpix P510 Lens Casing Replacement: step 5, image 1 of 2 Nikon Coolpix P510 Lens Casing Replacement: step 5, image 2 of 2
    • Unplug the two ribbon cables to completely detach the back.
  6. Nikon Coolpix P510 Lens Casing Replacement: step 6, image 1 of 3 Nikon Coolpix P510 Lens Casing Replacement: step 6, image 2 of 3 Nikon Coolpix P510 Lens Casing Replacement: step 6, image 3 of 3
    • With the back separated, you need to remove six 3mm PH000 Philips screws with a Philips screwdriver.
    • Remove one 5mm PH00 Philips screw
    • To remove the top right corner screw, you may need to lift the corner of the case to gain access to it.
    • With all the screws out, the metal plate should simply lift off.
  7. Nikon Coolpix P510 Lens Casing Replacement: step 7, image 1 of 2 Nikon Coolpix P510 Lens Casing Replacement: step 7, image 2 of 2
    • With the metal plate off, unplug this ribbon cable from the motherboard.
    • To remove the flat-topped connector, you simply lift it up to unplug it.
  8. Nikon Coolpix P510 Lens Casing Replacement: step 8, image 1 of 3 Nikon Coolpix P510 Lens Casing Replacement: step 8, image 2 of 3 Nikon Coolpix P510 Lens Casing Replacement: step 8, image 3 of 3
    • To get the lens assembly out, you need to remove four 6mm PH00 Philips screws
  9. Nikon Coolpix P510 Lens Casing Replacement: step 9, image 1 of 2 Nikon Coolpix P510 Lens Casing Replacement: step 9, image 2 of 2
    • With the support screws out, you can simply slide the assembly out of the casing.
  10. Nikon Coolpix P510 Lens Casing Replacement: step 10, image 1 of 3 Nikon Coolpix P510 Lens Casing Replacement: step 10, image 2 of 3 Nikon Coolpix P510 Lens Casing Replacement: step 10, image 3 of 3
    • If you are moving on to take the lens casing off, you do not need to do this step.
    • With the assembly out we need to take of this last piece by removing the three 3mm PH000 Philips screws.
  11. Nikon Coolpix P510 Lens Casing Replacement, Lens Casing: step 11, image 1 of 2 Nikon Coolpix P510 Lens Casing Replacement, Lens Casing: step 11, image 2 of 2
    • Remove five PH00 Philips screws with a Philips screwdriver.
  12. Nikon Coolpix P510 Lens Casing Replacement: step 12, image 1 of 1
    • Separate the lens casing from the front.
    • The switch on the side simply slides off of the front casing.
3 other people completed this guide.
Brian Hulsey
1,506 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 26
All Time: 3,299
