Nikon Coolpix P530 Battery Replacement
  1. Nikon Coolpix P530 Battery Replacement, Battery: step 1, image 1 of 1
    • Identify the battery chamber found at the bottom of the device.
    • Ensure the camera is turned off before conducting any maintenance on the device.
  2. Nikon Coolpix P530 Battery Replacement: step 2, image 1 of 3 Nikon Coolpix P530 Battery Replacement: step 2, image 2 of 3 Nikon Coolpix P530 Battery Replacement: step 2, image 3 of 3
    • Slide the switch to the left to open the battery chamber using your fingertip or plastic opening tools.
    • The spring loaded battery chamber door will swing open after the switch is moved.
  3. Nikon Coolpix P530 Battery Replacement: step 3, image 1 of 3 Nikon Coolpix P530 Battery Replacement: step 3, image 2 of 3 Nikon Coolpix P530 Battery Replacement: step 3, image 3 of 3
    • Depress the yellow spring loaded tab holding the battery in place using your fingertip or plastic opening tools.
    • After the yellow tab is depressed, the battery should partially eject from the camera.
  4. Nikon Coolpix P530 Battery Replacement: step 4, image 1 of 2 Nikon Coolpix P530 Battery Replacement: step 4, image 2 of 2
    • Gently remove the battery from the chamber.
3 other people completed this guide.
3 Comments
Thanks. Just checking the camera issues.
Suzanne von Leuschner - Reply
I can’t get the battery out of my camera. I've had the camera for 5 years with no previous problems. Any suggestions?
Bonnie Laub - Reply
top of the battery gets very hot when inserted .Is this normal?
Lowell Schiller - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 34
All Time: 3,994
