Nikon Coolpix P90 Battery Replacement
Elizabeth Kamine
Elizabeth Kamine and 5 other contributors
Last updated on July 2, 2024
1 minute
Very easy
Introduction
Go to step 1
Follow this guide to replace the battery of your Nikon Coolpix P90 camera with a fully charged EN-EL5 rechargeable Li-ion battery. It provides 3.7V and 1100mAh. Check your battery to ensure you are replacing with a compatible model.
Make sure that your camera is off and unplugged from the charger before you begin this repair.
  1. Nikon Coolpix P90 Battery Replacement, Camera Base: step 1, image 1 of 3 Nikon Coolpix P90 Battery Replacement, Camera Base: step 1, image 2 of 3 Nikon Coolpix P90 Battery Replacement, Camera Base: step 1, image 3 of 3
    • Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
    • Push the door open, and remove the existing battery with your fingers, per images 2-3.
Elizabeth Kamine
655 Reputation
6 Guides authored
Cal Poly, Team 20-14, Maness Winter 2015 Member of Cal Poly, Team 20-14, Maness Winter 2015
CPSU-MANESS-W15S20G14
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,184
