Nikon Coolpix S210 Back Case Replacement
  1. Nikon Coolpix S210 Back Case Replacement, Battery: step 1, image 1 of 1
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Nikon Coolpix S210 Back Case Replacement: step 2, image 1 of 2 Nikon Coolpix S210 Back Case Replacement: step 2, image 2 of 2
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
  3. Nikon Coolpix S210 Back Case Replacement, Back Case: step 3, image 1 of 1
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. Nikon Coolpix S210 Back Case Replacement: step 4, image 1 of 1
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. Nikon Coolpix S210 Back Case Replacement: step 5, image 1 of 1
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  6. Nikon Coolpix S210 Back Case Replacement: step 6, image 1 of 2 Nikon Coolpix S210 Back Case Replacement: step 6, image 2 of 2
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
To reassemble your device, follow these instructions in reverse order, paying careful attention to the locations of the different sizes of screws.
Paul Doyle
480 Reputation
3 Guides authored
Cal Poly, Team 5-17, Amido Winter 2011 Member of Cal Poly, Team 5-17, Amido Winter 2011
CPSU-AMIDO-W11S5G17
6 Members
12 Guides authored
One Comment
What about the front case so I can replace the flash board on top?
danwat1234 - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 2,299
