Nikon Coolpix S3500 Rear Buttons Replacement
  1. Nikon Coolpix S3500 Rear Buttons  Replacement, Back Panel Disassembly: step 1, image 1 of 2 Nikon Coolpix S3500 Rear Buttons  Replacement, Back Panel Disassembly: step 1, image 2 of 2
    • With the battery door facing upward, take your PH000 screwdriver and remove the 4 mm screws from the bottom of the device.
  2. Nikon Coolpix S3500 Rear Buttons  Replacement: step 2, image 1 of 2 Nikon Coolpix S3500 Rear Buttons  Replacement: step 2, image 2 of 2
    • After removing the screws, rotate the device to where the micro USB port is facing up.
    • Now, take your PH000 screwdriver and remove the two 4 mm screws from the device.
  3. Nikon Coolpix S3500 Rear Buttons  Replacement: step 3, image 1 of 2 Nikon Coolpix S3500 Rear Buttons  Replacement: step 3, image 2 of 2
    • Rotate the device 180 degrees so that the opposite side of the device is now facing upwards.
  4. Nikon Coolpix S3500 Rear Buttons  Replacement: step 4, image 1 of 2 Nikon Coolpix S3500 Rear Buttons  Replacement: step 4, image 2 of 2
    • After all of the screws are removed, rotate the device so that the bottom of the device is now facing upward.
    • With your index finger, press down and slide open the memory card/battery door.
  5. Nikon Coolpix S3500 Rear Buttons  Replacement: step 5, image 1 of 3 Nikon Coolpix S3500 Rear Buttons  Replacement: step 5, image 2 of 3 Nikon Coolpix S3500 Rear Buttons  Replacement: step 5, image 3 of 3
    • Now take the plastic opening tool, and place it in the seam of the device.
    • Now, work the tool around the seam of the device until you can safely pry open the device.
  6. Nikon Coolpix S3500 Rear Buttons  Replacement: step 6, image 1 of 2 Nikon Coolpix S3500 Rear Buttons  Replacement: step 6, image 2 of 2
    • Be careful when removing the back piece of your device.
    • Using your free hand, finish prying off the back piece of the device.
  7. Nikon Coolpix S3500 Rear Buttons  Replacement, Rear Buttons: step 7, image 1 of 1
    • Take the rear panel of the device in the palm of your hand with the buttons facing downward.
  8. Nikon Coolpix S3500 Rear Buttons  Replacement: step 8, image 1 of 3 Nikon Coolpix S3500 Rear Buttons  Replacement: step 8, image 2 of 3 Nikon Coolpix S3500 Rear Buttons  Replacement: step 8, image 3 of 3
    • On the back side of the device's rear panel, you will see the plastic brackets that hold the rear function buttons in place.
    • With your other hand, take the pry tool and start working your way around the edge of the buttons
  9. Nikon Coolpix S3500 Rear Buttons  Replacement: step 9, image 1 of 2 Nikon Coolpix S3500 Rear Buttons  Replacement: step 9, image 2 of 2
    • Now, take the hand that was previously holding the pry tool, and finish pulling off the rear function buttons.
Jordan Rosemeyer
491 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 444
