Nikon Coolpix S5200 LCD Screen Replacement
  1. Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: step 1, image 1 of 3 Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: step 1, image 2 of 3 Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: step 1, image 3 of 3
    • There are four 0.1 mm screws holding the front and back of the camera together all along the outside of the camera
    • There should be four screws
  2. Nikon Coolpix S5200 LCD Screen Replacement: step 2, image 1 of 1
    • Use the Phillips Head screw driver head to remove the four 0.1 mm screws surrounding the outer edges of the camera
  3. Nikon Coolpix S5200 LCD Screen Replacement: step 3, image 1 of 1
    • Pull the plastic back cover off of and away from the LCD screen
  4. Nikon Coolpix S5200 LCD Screen Replacement: step 4, image 1 of 1
    • Carefully remove the LCD screen from the silver plate that once held it in place by pulling it away from the internal components
  5. Nikon Coolpix S5200 LCD Screen Replacement: step 5, image 1 of 1
    • Remove the six designated screws sized 0.1 mm from the metal plate using a Phillip's Head screwdriver in size PH00.
  6. Nikon Coolpix S5200 LCD Screen Replacement: step 6, image 1 of 1
    • Lift the metal plate away from the internal components of the camera
  7. Nikon Coolpix S5200 LCD Screen Replacement: step 7, image 1 of 2 Nikon Coolpix S5200 LCD Screen Replacement: step 7, image 2 of 2
    • Carefully remove the LCD screen by pulling it away from the camera. Repeat these steps in reverse order to install the new LCD screen.
Andy Powers
391 Reputation
3 Guides authored
One Comment
Shouldn't the replacement LCD screen be considered a part? It is in fact very difficult to replace it without having the part to replace.
joshronsen - Reply
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 27
All Time: 1,099
