Nikon Coolpix S630 Battery Cover Door Replacement
  1. Nikon Coolpix S630 Battery Cover Door Replacement, Battery Compartment: step 1, image 1 of 1
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Nikon Coolpix S630 Battery Cover Door Replacement, Battery: step 2, image 1 of 1
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Nikon Coolpix S630 Battery Cover Door Replacement, Memory Card: step 3, image 1 of 1
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Nikon Coolpix S630 Battery Cover Door Replacement, Back Cover Removal: step 4, image 1 of 3 Nikon Coolpix S630 Battery Cover Door Replacement, Back Cover Removal: step 4, image 2 of 3 Nikon Coolpix S630 Battery Cover Door Replacement, Back Cover Removal: step 4, image 3 of 3
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  5. Nikon Coolpix S630 Battery Cover Door Replacement: step 5, image 1 of 1
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  6. Nikon Coolpix S630 Battery Cover Door Replacement, Detaching Ribbon: step 6, image 1 of 2 Nikon Coolpix S630 Battery Cover Door Replacement, Detaching Ribbon: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
  7. Nikon Coolpix S630 Battery Cover Door Replacement, Front Cover: step 7, image 1 of 1
    • Locate a small, rectangular flap above the battery cover door.
    • Push the small, rectangular flap back through the hole.
  8. Nikon Coolpix S630 Battery Cover Door Replacement: step 8, image 1 of 1
    • Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
    • Make sure to hold the camera down when removing the front cover.
  9. Nikon Coolpix S630 Battery Cover Door Replacement, Battery Cover Door: step 9, image 1 of 1
    • Locate the battery cover door.
  10. Nikon Coolpix S630 Battery Cover Door Replacement: step 10, image 1 of 2 Nikon Coolpix S630 Battery Cover Door Replacement: step 10, image 2 of 2
    • Press and slide the cover door open.
  11. Nikon Coolpix S630 Battery Cover Door Replacement: step 11, image 1 of 1
    Buy
    • Locate the small rod that is securing the door in place
    • Using a tweezers, grab the rod and slowly pull the rod out
    • Be careful as you try to pull the rod out because the spring may pop out
  12. Nikon Coolpix S630 Battery Cover Door Replacement: step 12, image 1 of 1
    • Replace battery cover door.
    • To reinstall a new battery cover door, make sure you have these parts: spring, rod, and the battery cover door.
  13. Nikon Coolpix S630 Battery Cover Door Replacement: step 13, image 1 of 1
    • Place battery cover door back into place with spring between the insertion holes.
    • Using a tweezers, gently slide the rod through the insertion holes and through the spring.
Aulivia Bounchaleun
10 Reputation
4 Guides authored
Cal Poly, Team 8-56, Johann Spring 2013 Member of Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 Members
18 Guides authored
One Comment
I am stuck on step 8. How am I supposed to hold it down and pull the front cover off. I can only get the corner up where the battery goes.
toolshell - Reply
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 17
All Time: 1,716
