Nikon Coolpix S6300 Buttons Replacement
  1. Nikon Coolpix S6300 Buttons Replacement, Battery: step 1, image 1 of 1
    • Place the camera facing upwards.
    • Press down on the battery cover and slide towards the front face of the camera.
  2. Nikon Coolpix S6300 Buttons Replacement: step 2, image 1 of 1
    • Rotate the orange battery clip in the camera to release the battery.
  3. Nikon Coolpix S6300 Buttons Replacement, Buttons: step 3, image 1 of 3 Nikon Coolpix S6300 Buttons Replacement, Buttons: step 3, image 2 of 3 Nikon Coolpix S6300 Buttons Replacement, Buttons: step 3, image 3 of 3
    • Locate the eight outer PH 2mm screws on the device.
    • Using the PH00 screwdriver remove all of the screws from the camera.
  4. Nikon Coolpix S6300 Buttons Replacement: step 4, image 1 of 3 Nikon Coolpix S6300 Buttons Replacement: step 4, image 2 of 3 Nikon Coolpix S6300 Buttons Replacement: step 4, image 3 of 3
    • Using a plastic opening tool, gently pry off the front and rear plates.
    • Be patient with this step, do not force the clips holding the plates together.
  5. Nikon Coolpix S6300 Buttons Replacement: step 5, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the PH 2 mm screw located to the right of the screen, above the OK dial.
  6. Nikon Coolpix S6300 Buttons Replacement: step 6, image 1 of 1
    • Disconnect the connectors using a plastic spudger.
    • Be careful when removing the cables to prevent damaging the connectors.
  7. Nikon Coolpix S6300 Buttons Replacement: step 7, image 1 of 1
    • You may now remove the internal panel of the buttons.
Michael Lynch
396 Reputation
3 Guides authored
USF Tampa, Team 1-2, Remmell Fall 2015 Member of USF Tampa, Team 1-2, Remmell Fall 2015
USFT-REMMELL-F15S1G2
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 825
