Nikon Coolpix S6300 Zoom Lens Gears
Hung
Hung and 3 other contributors
Last updated on May 7, 2024
30 minutes
Moderate
Needs Better Images
Action Shots
Missing Steps
Introduction
Go to step 1
After following the prerequisite guides, the gear can reached by removing the lens apparatus. When the primary gear is exposed, it can simply be lifted out of the camera and inspected.
Tools
  1. Nikon Coolpix S6300 Zoom Lens Gears, Battery: step 1, image 1 of 1
    • Place the camera facing upwards.
    • Press down on the battery cover and slide towards the front face of the camera.
  2. Nikon Coolpix S6300 Zoom Lens Gears: step 2, image 1 of 1
    • Rotate the orange battery clip in the camera to release the battery.
  3. Nikon Coolpix S6300 Zoom Lens Gears, Buttons: step 3, image 1 of 3 Nikon Coolpix S6300 Zoom Lens Gears, Buttons: step 3, image 2 of 3 Nikon Coolpix S6300 Zoom Lens Gears, Buttons: step 3, image 3 of 3
    • Locate the eight outer PH 2mm screws on the device.
    • Using the PH00 screwdriver remove all of the screws from the camera.
  4. Nikon Coolpix S6300 Zoom Lens Gears: step 4, image 1 of 3 Nikon Coolpix S6300 Zoom Lens Gears: step 4, image 2 of 3 Nikon Coolpix S6300 Zoom Lens Gears: step 4, image 3 of 3
    • Using a plastic opening tool, gently pry off the front and rear plates.
    • Be patient with this step, do not force the clips holding the plates together.
  5. Nikon Coolpix S6300 Zoom Lens Gears: step 5, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the PH 2 mm screw located to the right of the screen, above the OK dial.
  6. Nikon Coolpix S6300 Zoom Lens Gears: step 6, image 1 of 1
    • Disconnect the connectors using a plastic spudger.
    • Be careful when removing the cables to prevent damaging the connectors.
  7. Nikon Coolpix S6300 Zoom Lens Gears: step 7, image 1 of 1
    • You may now remove the internal panel of the buttons.
  8. Nikon Coolpix S6300 Zoom Lens Gears, Display: step 8, image 1 of 1
    • Remove the clasp from the ribbon cable using the plastic spudger.
    • Make sure to be gentle when removing the clasp to prevent it from ripping.
    • You may now remove the display.
  9. Nikon Coolpix S6300 Zoom Lens Gears, Polarizing Lens: step 9, image 1 of 3 Nikon Coolpix S6300 Zoom Lens Gears, Polarizing Lens: step 9, image 2 of 3 Nikon Coolpix S6300 Zoom Lens Gears, Polarizing Lens: step 9, image 3 of 3
    • Remove the four PH00 2.5 mm screws around the edges of the display plate.
    • Remove the three PH00 2 mm screws from the sides of the buttons plate and the 2.5 mm screw from the center of the buttons plate.
    • Lift the buttons plate out of the camera with the plastic tool.
    • Lift the display plate out of the camera with the plastic tool.
  10. Nikon Coolpix S6300 Zoom Lens Gears: step 10, image 1 of 3 Nikon Coolpix S6300 Zoom Lens Gears: step 10, image 2 of 3 Nikon Coolpix S6300 Zoom Lens Gears: step 10, image 3 of 3
    Tool used on this step:
    • Use the plastic opening tool to gently flip the white folders at the end of the ribbon cables.
    • Use this tweezers to gently pull the cables out of the holders.
    • Lift the lens apparatus out of the rest of the camera by pushing the front of lens up from the bottom.
  11. Nikon Coolpix S6300 Zoom Lens Gears: step 11, image 1 of 2 Nikon Coolpix S6300 Zoom Lens Gears: step 11, image 2 of 2
    • Use the plastic opening tool to flip the two white clips holding the ribbon cables.
    • Use tweezers to pull the cables from clamps.
    • Use the PH00 screwdriver to remove the three 2 mm screws around the first lens area.
  12. Nikon Coolpix S6300 Zoom Lens Gears: step 12, image 1 of 2 Nikon Coolpix S6300 Zoom Lens Gears: step 12, image 2 of 2
    • Lift the first lens from the rest of the lens apparatus.
    • Use thin tweezers to left and remove the polarizing lens from the apparatus.
  13. Nikon Coolpix S6300 Zoom Lens Gears, Zoom Lens Gears: step 13, image 1 of 1
    • Check to see if there are any items stuck inside the gear.
    • Carefully remove items using tweezers.
    • If the gears are popped out of place, carefully push the gears back into its original position shown in the picture
4 other people completed this guide.
Hung
383 Reputation
2 Guides authored
USF Tampa, Team 1-2, Remmell Fall 2015 Member of USF Tampa, Team 1-2, Remmell Fall 2015
USFT-REMMELL-F15S1G2
5 Members
10 Guides authored
One Comment
Attention rester sur une table, et bien suivre le tutoriel. En effet, il y a des pilles, Pas la batterie: donc si vous touchez le haut de l'appareil, il y a un peux d’électricité max 4w , ce qui surprend....C'est pas dangereux mais cela surprend. Pas toucher le haut de l'appareil..... Ferreria J-C
a420mf - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 1,524
